| Navigation lights My understanding is that for vessels <12m one needs port & stbd navigation lights plus (at a minimum) an all-round white masthead light. Also that there should be a minimum 1 metre vertical separation between the sidelights and the masthead light. How then do 3-in-1 combination lights comply? |
| Mat, I think you're slightly confusing the rules for sail and powered vessels, but to clarify... from Hella's tri-colour installation manual: Quote:
| Tri-lights don't display a 360 white but the stern white light. The 360 is for anchoring.
__________________ Gonzo |
| Thanks Will, Gonzo. Didn't realise the separate parts of the light are individually switched, but that has it explained... ![]() |
Your anchor light can double as an all round white if you are under power, but you also need separate port and starboard lights in this condition. So you need four lights in total. Last edited by murdomack : 05-26-2011 at 03:10 AM. Reason: last para |
| Here's a website that may be of interest to everybody, http://www.boatus.org/onlinecourse/r...ect/info2c.htm |
| Much appreciation for all who responded to this. As I prep my boat for sea, I'm pulling the mast & was going to put a masthead tri-colour on. Shamefully, my ColRegs knowledge is a bit rusty. You've not only answered an issue for me but have pushed me to re-read my ColRegs! Mike |
| Navigation Light Switch Panel with warning lights | Blain Albin | Electrical Systems | 10 | 03-31-2011 06:12 PM |
| Ies Lights And Nav Lights In Rhino | Sean Herron | Software | 2 | 02-01-2008 09:09 PM |
| Navigation lights for large (>65') sailboat | Scott Carter | Sailboats | 3 | 02-04-2007 07:01 PM |
| ship navigation lights illustrated | Richard Hillsid | Open Discussion: All Things Boats & Boating | 2 | 10-01-2006 12:25 AM |
| Navigation lights - LED's | Dutch Peter | Boatbuilding | 7 | 12-13-2004 01:09 AM |
