Measuring pressure diffferences
Discussion in 'OnBoard Electronics & Controls' started by rwatson, Jul 1, 2013.
  1. TANSL
    Likes: 706, Points: 123, Legacy Rep: 300
    TANSL Senior Member
    Have you taken into account the elongation of the spring can not be directly proportional to the pressure, as you call it, exerted by the engine ?. The spring constant may change, not be constant, from a certain elongation.
    Maybe you will need to draw previously, using a calibrated apparatus, the pressure vs elongation curve of the spring.
    Maybe I'm wrong and I'm complicating what is simple.
  2. rwatson
    Likes: 495, Points: 83, Legacy Rep: 1749
    rwatson Senior Member
    Yes indeed - a very valid point. I cannot assume the rate of change will be linear at all.
    I am going to have to individually measure the 'pressure' applied at each level.
    While I think about it, I will need to establish an upper and lower possible range
    From observed tests, I would imagine the range would be from Zero to no more than 100 grams per square centimetre.
    If I can accurately detect the difference, I have to equate them to equivalent power at 1:5 scale.
    http://www.allconversions.com/
    Assuming the Propeller is say, a square centimeter in area,
    maybe that provides a conversion of .1 Kilograms per square centimeter, to provide a Force measurement of 0.980665 newtons per square centimeter
    If I can convert that Force Unit x the mass of the boat , does that give me the Power required measurement, which can be scaled up ?
    I will need to get onto a science forum to verify the logic.
  3. TANSL
    TANSL Senior Member
    I'm afraid I can not answer your questions because it is a very specific field, of which I am not an expert and therefore, I could say a lot of nonsense.
    Only two points to note:
    1. Force x mass of the boat does not give anything valid.
    2. The extrapolation of the values ​​obtained with a model to the real boat is an operation involving many complicated factors and dimensionless numbers.
  4. cmckesson
    Likes: 7, Points: 18, Legacy Rep: 55
    cmckesson Naval Architect
    A whoopi cushion
    Being a fluids guy, I liked the original manometer-based idea. Maybe a balloon - something like a hot water bottle - with a clear plastic tube sticking straight up. Height of fluid in tube yields pressure in balloon. Contrive boat-to-balloon-to-motor interface such that areas are known and remain constant, say two identical 2" square blocks.
    Force on blocks must be in equilibrium with pressure in balloon, et voila monsieur.
  5. rwatson
    Thanks for those observations.
    Now that I see the points, it would have to be Force x Mass x Velocity
    edit: Note to self - Not velocity, Acceleration ?
    You are right about extrapolating to the real world.
    I am content with 'indicative' results, so that I have a fair confidence I don't build a hull that is a real underperformer.
    I would hate to be in a project where I was getting a hull designed in a totally radical shape - that would be scary. Luckily, I am in a fairly well traveled area.
    I have also had supporting calculations done ( attached )
    Thanks for the input Tansl :)
  6. rwatson
    This still intrigues me too.
    The actual mechanism eludes me though, both its placement and the data capture method.
    Maybe what I should be thinking of is instead of a spring in the tilt control with indicators, is should push a head of liquid up a vertical pipe, or even pull a column up ?
  7. TANSL
    TANSL Senior Member
  8. rwatson
    Yes, I tried one out for other purposes, but I couldn't get reliable results. The hull angle through waves seemed to have bad effects
    My Science mates have been checking the formulae
    http://www.sciencechatforum.com/viewtopic.php?p=267397#p267397
    I had to draw up better diagram for them,
    So far
    Force times speed = power
    Say the force is 1 Newton, and the speed attained with that force is 1 meter/second.
    Then the power is what you get by multiplying the two: 1 Newton meter per second = 1 Joule per second
    = 1 Watt.
    1 joule per second = 0.00134102209 horsepower
    http://www.aqua-calc.com/what-is/power/joule-per-second
  9. BMcF
    Likes: 182, Points: 63, Legacy Rep: 361
    BMcF Senior Member
    In a somewhat similar fashion, all of our testing with outboard-powered models is done with pancake load cells reacting motor thrust. We always calibrate the measurement end-to-end by pulling on the lower unit, prop shaft centerline, with a fully certified-calibrated tension load cell.
    The outboards are not mounted directly to the transom though..we mount them on a hinged plate with composite bearings in the hinge. In the pics below are front and rear shots of a 4-engine mounting and thrust measurement setup for a 37-foot experimental craft we were working on. Each of those tubular extensions is for the reaction link from the engine plate to connect to a load cell inside the transom of the boat.
  10. rwatson
    Yes - but what do you use on 1:5 scale setups ? - manufacturer and brands appreciated.
    Its good to get a bit of verification of the process - with a hinged motor system.
    Very interesting post Mr B
  11. rwatson
  12. BMcF
    BMcF Senior Member
    That WAS a 1:5 model..more or less. Heck, we built and operated a 1:20 free-running remote-controlled model for ONR that was 57-feet LOA. ;)
    We use exclusively Strainsert load measurement devices. Here is a pic of a smaller pancake thrust cell that is used on one of our outboard motor hinge brackets that supports engines in the 70-115HP range (the mounts in the earlier pic support up to 300HP each, for comparison. Much smaller ones are available; we've used them on little baby Yamaha 2.5 HP outboards even.
  13. rwatson
    A bit too big for a 10 kilo model unfortunately
    Putting this link in here for a 50kg RC Model Load Sensor
    https://www.sparkfun.com/products/10245
    "For anyone trying to build a somewhat precise scale with this sensors please DO NOT use them. Their accuracy and repeatability is very poor"
    Extra Data
    p = F ÷ a. pressure = Force ÷ area.
    F = m x a. Force = mass x acceleration.
    http://www.gcsescience.com/peq.htm
    So to use Pressure to calculate Force, I would need to know the acceleration rate,
    Not looking hopefull :=(
  14. rwatson
    What are you waffling on about strain gauges for ? :p
    You should be able to tell me how to do the Power calculations I need ?
  15. BMcF
    BMcF Senior Member
    ?? No you don't...pressure x area = force. Force/area = pressure
    We've used pressure tension setups during bollard and towed-model tests many times. A hydraulic cylinder and a pressure gauge and there you are. We towed a 13.5-meter model (it was 1:4 scale at that size) with a rig like that.
    You mentioned a teeny tiny model though..10 kg?? We probably carry more than 10 kg of beer on board some of our scale models....like this 1:4 scale model.
