| Joystick Control System Guys, I need some information about joy stick control system. I want to know how to install it in my ship, thanks for ur help |
| Installing the joy stick and the computer is the easy part. Digital electronic throttle control for your engine(s) is a requirement, so is electric gear shift. And of course the steering must also have a digitally actuated servo system. With twin engines you could completely omit the steering, even remove the rudders, but you get into big problems if one engine fails. The computer program must be fine-tuned so the movement of the stick exactly matches the movement of the boat. An interesting project, please keep us informed. |
| A gimble is four resistor circuits. There's a mecnanical set up that moves the toggle arms of switches. You dot need to buy a Gimble arrangement if your inventive. Otherwise, get the gimble. The +12V is the supply. That comes in from the center pin, then it goes out one of the four resistors to do some kind of work. If you had 12V trolling motor back there you'd connect the FWD voltage wire to the Rearmost Gimble switch. The further Fwd you move the gimble, the faster the motor goes. LEft n' right for turning, Fwd n' back for speeds Fwd, and reverse. I had another switch in the planning stage to lift the trolling motor. |
| Servo Assisted/Joystick sailing dinghy | albentley | Boat Design | 7 | 11-03-2008 09:12 PM |
| FORSALE Gelcoat system/Resin System | cbboatworks | Marketplace | 1 | 05-04-2007 05:52 PM |
| Remote control boat | warlordseven | Boat Design | 17 | 09-07-2005 03:07 PM |
| Control over 60 mph | Richard Petersen | Boat Design | 5 | 01-10-2005 11:27 PM |
| rudder control | Danielsan | Boat Design | 14 | 10-07-2004 07:54 AM |
