Old 07-26-2011, 07:59 PM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
Isolated Earth Alternators?
What your view on isolated earth alternators, jap and european engine marinisers seem to use them and US ones usually dont?
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 08-13-2011, 08:39 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
presumably they want to wire the house system insulated return and put the starting battery with its own alternator next the engine doing only that job.
presumably the yanks have decieided its not worth the effort/cost and the only things which need them by law are petrol tankers ...
Old 09-11-2011, 04:28 PM
goboatingnow goboatingnow is offline
Rep: 74 Posts: 65
Why dump DC negative transients through the block when you don't need to. If you have access to a isolated DC negative, then it's a better solution
Dave
Old 09-11-2011, 06:50 PM
Rep: 324 Posts: 591
I am a yank and I always build them isolated if I can and recommend to owners that don't have it, to change it over. If sending units do not have a double pole setup then it is kind of moot isn't it? That is the second part of the that PITA to change over.
Old 09-12-2011, 06:56 AM
correct
but who ever changed a block out because the charging earth ran through it to the neg battery terminal and damaged it?
Old 09-12-2011, 07:43 AM
Rep: 324 Posts: 591
Originally Posted by powerabout View Post
correct
but who ever changed a block out because the charging earth ran through it to the neg battery terminal?
Huh?...You only need to change the alternator and sending units.
Old 09-12-2011, 02:59 PM
BertKu BertKu is offline
Rep: 130 Posts: 1,035
The advantage is that one can then have 2 alternators running on the diesel and have the 12 Volt and 24 Volt batteries charged.
Bert
Old 09-12-2011, 06:18 PM
Bert
you dont need isolated earth to do that.
So whats the problem you are solving with isolated earth?
Old 09-12-2011, 06:36 PM
Rep: 74 Posts: 65
Impressed current corrosion.
Old 09-12-2011, 06:50 PM
How will you notice that is happening to your engine?
Old 09-13-2011, 12:52 AM
Rep: 670 Posts: 2,457
Corrosion in Exhaust system, pumpshafts, heat exchangers...anything wet.
Old 09-13-2011, 01:00 AM
Michael
Whats the physics of that, what is the circuit that is running via the sea water ( other than normal 2 dissimilar metals in an electrolyte) that involves the negative/earth of the battery/alternator
Old 09-13-2011, 01:09 AM
How do you know that the current is negative ?
Old 09-13-2011, 01:21 AM
cant find any info on that
but plenty of corrosion protection systems by using Impressed current
Old 09-13-2011, 01:30 AM
Yes indeed..it is possible to deploy an impressed current corrosion protection system. I have used them...not cheap...and they must be constantly monitored.
Earth Race fhrussell Multihulls 24 08-29-2011 02:35 AM
Diatomaceous earth SeaJay Fiberglass and Composite Boat Building 23 10-15-2010 04:12 PM
Can you parallel two alternators? IamBarry Electrical Systems 9 09-24-2009 11:45 PM
Why are marine alternators so darn $$$! ted655 OnBoard Electronics & Controls 35 01-18-2008 09:53 AM
isolated backstay construction wndsnd Sailboats 5 05-11-2006 01:18 PM
