#31
| Capt Are you saying the ABYC std is out of date as well as the sterling data? That sounds right to me. Cheers
__________________ Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers..... |
#32
| The ABYC std has changed since 2002 mentioned in the Sterling quote only by incorporating an open circuit warning but it was never a standard for the UK at least, in fact the UK electrical regs stated that no switched device should be in an earth wire, which is what a GI is. However there are some failsafe GI available from a US firm called Dairy something... I'll have to look it up. |
#33
http://www.dairyland.com/products/GI |
#34
| I think you should take professinal advice on this ..certainly the hull should be earth ....I know you are not on 240v but many have been killed getting off boats not knowing the hull was at 240v and the bank was earthed . You must comply with your countries regulations and that of the marina .. I have not seen the words "qualified Marine electrician" under anybodys name on this site |
#35
#36
| Dont take the advice of well meaning idots get someone to do it who your wife can sue when you get killed ..... |
#37
#38
#39
| Digital Inverter Generator Technology | 44Kebeck | Electrical Systems | 8 | 02-08-2010 08:52 PM |
| How To Isolate A Alternater Question | dermo | Electrical Systems | 6 | 03-25-2009 08:00 AM |
| power inverter 12vDC to 240vAC | sebski | OnBoard Electronics & Controls | 26 | 07-28-2008 05:24 PM |
| Shorepower | Swimpy | Electrical Systems | 17 | 01-24-2007 06:28 PM |
| Hybrid - Genset-Inverter | Charlie-Papa | Boat Design | 3 | 07-23-2005 11:57 AM |
