| Hydrolic steering Is it common for a 43 ft sailboat with hydrolic steering (one station only) to require six turns lock to lock or do I have a problem? |
| I don't know specifically about your hydraulic steering system but three turns lock to lock seems average from what I understand. There is most probably a way to adjust it. I'm assuming it is a wheel pump to a linear piston, if so you can shorten arm on the piston to lessen the lock to lock turns. Mike |
| 6 is perfect and is what would be required for a hydraulic auto pilot. Pump and cylinders are matched before purchase. a 1 liter pump and a 6 liter cylinder would need 6 turns to move the cylinder its length, just an example--usually calculated in cc's . Look up Vetus. |
| Self steering with steering oars? | Alex.A | Boat Design | 8 | 04-25-2010 11:04 AM |
| Hydrolic System for Spud | internetturk | OnBoard Electronics & Controls | 2 | 08-30-2009 03:39 PM |
| self steering | bill broome | Multihulls | 35 | 12-07-2008 11:06 PM |
| Self steering | Manie B | Boatbuilding | 11 | 11-14-2008 11:25 PM |
| Hydrolic tranny problem | IMSETFREE | Diesel Engines | 4 | 10-09-2006 02:49 AM |
