| Hydraulic pump on PTO engine Hello, I would like to ask if somebody has experience in building a hydraulic pump on the PTO of a propulsion engine (John Deere). I am planning to feed the steering gear by that pump as well as the bow thruster. Therefore I would like to know how much hp/kw such a pump (the biggest one with AES-B flange) draws from the engine. |
I would advise go hand hydraulic, ie not eng driven fo steering and the go to vetus website for your thruster requirements |
| It will draw as much as the load you attach to it
__________________ Gonzo |
| What was the reason you choose for Vetus Deutz? With a hand driven pump you mean a orbitrol whereon the steering wheel is directly attached to? That is what I will do anyway, but specially for steering the boat while on automatic pilot I want to avoid a electrical hydr. pump. |
| i chose Vetus deutz, for the strong reliable 4 cylinder yes go look for hydrive, , wagner, or vetus hand hyd leave belt driven pump alone, In Netherlands you have ALL to access Vetus has a big pdf catalogue |
| You mean to say that if you don't use hydraulic driven things you don't draw hp/kw as well? Anyway I am planning to attach a hydraulic bow thruster of 20-25 hp to it which I want to have it able running full power simultaneously with operating a steering gear of 200kgm/300cc. The engine is a John Deere 6068TFM75 (200kW). |
| what does that eng cost there |
You will have a pump running big enough for the bow thruster yet all it is doing is auto pilot work. The electric hydraulic pumps are easy and will connect up nicely to your fluxgate control. Lots of waisted power there. Sledge hammer for a walnut. How big is the boat and auto pilot |
| If you are asking what the idle resistance is, you need to look at the specifications of the pump you are installing. If not it is like asking how much fuel does a boat use.
The boat is 17 mtr long, I don't know yet which Autopilot I will choose. |
| The hydraulic pump does not run all the time unless you use a constant running pump for bigger boats. These 12V pumps will use spurts of approx 6 amps and depending on the gain setting they will pump approx 1/2 second in three. A miniscule draw. |
| I also consider a hydraulic system as more reliable and a more flexible solution: It is always possible to expand the system as soon as you have a basic system. Perhaps I decide to install two pumps: one on the engine PTO for steering and one on the gearbox which is 'clutchable' for the bowthruster etc. Another question: Does anybody has experience in the noise produced by such hydraulic pumps/sytems and is a oil cooler always required? |
| Hydraulic oil coolers are often necessary, but not always. Hydraulic pumps and motors all have preferred oil viscosity ranges; as oil heats up, it loses viscosity. Your pump/motor supplier of choice should be able to provide you with the appropriate charts and formulae for the parts you choose. Most engine-driven hydraulic pumps, IMHO, should be of the variable-displacement variety, under some form of load sensing control. There are about half a dozen common ways of doing load-sensing; again, your supplier should be able to point you to the version that is appropriate for the pump you choose. If the pump is only going to be used for a bow thruster, a clutched fixed-displacement pump might provide adequate service for your needs. In all cases, there are fairly simple equations for relating the torque, power, pressure, displacement, RPM and flow rate of whichever hydraulic pump or motor you choose. The problem with engine-driven power steering is that if your engine dies for any reason- most likely wet or dirty fuel- you loose steering as well. With electric pumps, they won't consume battery life while the engine's running (since the alternator is providing all the DC at that point), but they also won't shut your steering down if the engine stops. I've been hearing some good things about WH autopilots ( http://www.whautopilots.com/ ) for larger boats with hydraulic steering, but I have yet to get my hands on one to see if the hype is for real.
big saving, plus the mtgs sit higher up the block, so you can get the eng lower BUT JD is a very good eng I did not buy cos JD France wanted too much, and would not give a builders discount, those prices above in French marine are retail; |
| PTO/PTI mode with engine running... | ideaEngineering | Boat Design | 7 | 12-08-2009 03:11 AM |
| choosing a hydraulic helm pump | dalessandro | OnBoard Electronics & Controls | 3 | 02-12-2009 10:13 AM |
| is using FPP with fire pump and shaft alternator on maine engine's PTO possible | bahgota | Boat Design | 1 | 08-02-2008 09:26 AM |
| Small-scale PTO | JPC | Propulsion | 2 | 12-22-2005 10:46 PM |
| Heat Pump => Vacuum Pump | Inquisitor | Boatbuilding | 7 | 11-12-2005 10:29 PM |
