Old 01-25-2011, 06:12 AM
Stillbuilding Stillbuilding is offline
Rep: 10 Posts: 7
Hydraulic bowthruster RPM
Does anyone know usual RPM for a 12" bowthruster? Just curious.
Old 03-03-2011, 11:04 AM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
http://www.usthrusters.com/hthrusters.asp
Hard to say, what the prop shaft rpm is, as the gear ratio is not specified, but hydr.motor rpm is around 3000 rpm (57 liters/min, 19.5 ccm).
Edit: Model SP 300 Hyd
Lurvio
Hopefully creating something useful, since 1983.
Old 03-03-2011, 09:08 PM
Rep: 10 Posts: 7
Presumably a geroter motor is used in most cases providing some sort of reduction gearing. No guesses for the thruster prop RPM?
Old 03-06-2011, 05:13 AM
Adler's Avatar
Adler Adler is offline
Rep: 110 Posts: 98
Dear,
More or less a 12" Dia-Ducted propeller(eff 0.65-0.67) of a thruster absorbs 25kW Hyd.Power at 1350-1450 rpm. (more speed , reduces the propeller's efficiency when the cavitation appears on blades' tip).
Most of these systems use piston motors (because of the better efficeincy than the orbit or gerotor type motors) and reduce the motor's speed through the L drive gears by a ratio 1.3 to 1.5.
If you consider all these above you need a Hyd.Motor to operate at 250 bars (continuous mode - able to achieve 350 bars) with a displacement 40-45 cm3/rev. and top speed never less than 2500rpm.
I hope all these help you regarding the case.
Old 03-07-2011, 02:33 AM
Rep: 10 Posts: 7
Adler, Thanks very much for that. All very clear. Will help with my plans.
prop rpm jeemboNC Inboards 41 11-17-2007 08:37 AM
max rpm on 5.7L jagrimes Sterndrives 2 09-28-2006 11:29 PM
6400 rpm is too much riveramunizaga Powerboats 1 09-09-2005 08:11 AM
bowthruster blown RDB Electrical Systems 8 10-28-2004 04:45 PM
bowthruster max Boat Design 2 09-12-2003 02:39 AM
