Old 08-23-2008, 01:30 AM
Boater1524 Boater1524 is offline
How to wire in simple front and back lights to fish at night
I want to wire in one switch that can turn on both my front and back lights simultaneously. I have a grounding bus bar and a glass fuse panel so i'm thinking if I get a small bus bar and use one of the free slots on my fuse panel I could run a wire from my fuse panel to the small bus bar and then would attach both the front and back positive leads while connecting both the grounds to my grounding bus bar? If there is an easier way to do this or if this isn't the correct way please let me know.
Thanks
Old 08-23-2008, 02:01 AM
BHOFM BHOFM is offline
Rep: 247 Posts: 458
If you are talking about your running lights and stern light,
they have different purposes. if you are not moving, tied
up, anchored, only the stern light should be on. if you
are moving, both should be on! I think they check that if
you get inspected on the lake!
If you are just adding some lights, they can be wired together
just run a + to a good switch, proper rating, and then to the
lights, ground the - to your bar, if you have a free fuse, just
use that no need to add to and cause a problem, If you need
a new bar, make sure it is fused to the main power source!
Also check the wire to the ground bar and make sure it
is big enough to handle the added load!
Old 08-23-2008, 11:58 PM
redtech redtech is offline
Rep: 22 Posts: 252
if it is nav and anchor light on one toggle switch that is easy
you need a three pos. switch (one-off-on) with six poles on it or to say it eazier a six pole three position switch
the middle poles will be battery positive (fused)
the top right pole in nav and top left anchor
the bottom poles you only need a jumper from one of them to the anchor light
Motorsailer with pilothouse in front YuriB Motorsailers 18 06-24-2008 07:04 AM
Late Night Runs TripleCrownNC Fiberglass and Composite Boat Building 51 06-17-2008 08:15 AM
Front End Engineering Department pashbe1 Boat Design 1 04-21-2008 09:54 AM
Ies Lights And Nav Lights In Rhino Sean Herron Software 2 02-01-2008 10:09 PM
Tahoe Q-3 2001 Lights and Fish Holding Wiring Fes Boat Design 0 07-20-2006 08:47 PM
