| How to Link NMEA from GPS To RS232 ON PC I have Navman Chartplotter I want to link The NMEA Out put to My pc via RS232. I know you attach the nmea output from gps to input on rs232 and visa versa but it does not seem to work do i need to do anything with the ground on the rs232 ? Many THanks |
| http://en.wikipedia.org/wiki/RS-232#Connectors Has the pinouts for various serial port connectors. So, for a typical 9=pin serial port connector, you'd connect the GPS ground to pin 5 and the GPS NMEA output to pin 2. This assumes that the serial port will work OK with TTL (0..5V) levels, which most will. RS232 was originally made to use levels of plus and minus 12 volts, but most modern receivers use a switching point of plus 2 volts or so, and it works for 0 to 5 . You might use some terminal program to be sure you are getting characters reeceived before using more complex software. Let us know what happens.
| ja, terry is right, then check baud rate then enable the correct port, used to do this a lot but bit rusty will think on it!!!! |
| Thanks Guys I will use hyper terminal just so i can see data is comming accross. Does anyone know what the Braud rate/ parity and other settings would be ? |
| 9600 baud, 8 bits, NP. The GPS must first be told to use NMEA, the default is Navman's own protocol with much higher baud rate. |
| Then the pointer on the screen thinks the input from the nmea through the 232 looks like a mouse. The pointer goes berserk. easy to fix ,--google it. |
| Hi TerryKing. There is an expression for this I think: something with a mouth and a foot. You are right of course. I've spent so many years between modems, the answer came as a reflex. Analog group 3 fax machines use 9600 baud, so did the old genius mouse... |
| Thannks guys I have made my cable ill test it tonight and let you know how i get on |
| Ok great that works but i have got a problem you guys might be able to help with. The first is I Have a Navman 5500 Chartplotter Gps I can Only See one NMEA out Connection this also goes to my vhf as i have a panic button which beems my Gps co-oridnates to the coast guard when in trouble. The problem is it will only work with one or the other as in nmea data to my laptop or VHF is there any way of getting them both to work at same time. I have another plug on the back of my Chartplotter which in the manual states its can be used for a fuel transduser it looks the same as the main jack would it be the same pin out and have another nmea out that i can use Cheers |
| NMEA data out from the GPS can be hard-wired to more than one device because they are only listeners. You can make a Y-cable with on one side the RS232C plug with data-out, data-in and ground, the other side just data-out and ground to the VHF (the VHF will never talk back to the GPS). The fuel transducer plug is wired for that purpose only. It allows the plotter to keep track of the amount of fuel in your tanks if you have entered the tank data in the setup menu and tell it when you fill up. That function is not used by most owners because the transducer is expensive and not very precise. |
| Laptop interface to TackTick NMEA | tspeer | OnBoard Electronics & Controls | 37 | 06-29-2011 01:05 PM |
| Collecting GPS & TackTick NMEA to a USB or Flash | awaysailing | Software | 4 | 06-24-2009 08:38 PM |
| Discussion- Multipurpose Onboard Computers: Networks - Protocols - NMEA+others | TerryKing | OnBoard Electronics & Controls | 4 | 11-07-2007 10:55 PM |
| Cruzpro NMEA to computer -trouble | 40 Fathom Andy | OnBoard Electronics & Controls | 10 | 10-29-2007 10:33 AM |
| NMEA 2000 analog interface | DDW | Boat Design | 0 | 09-27-2005 01:49 AM |
