Old 04-22-2009, 06:05 PM
ftaloco ftaloco is offline
Rep: 10 Posts: 2
how to install a bilge pump @ 67 Slickcraft?
hi!
i just got my first boat wich is is a 67 slickcraft with a outboard evinrude 65 hp,
Im having some problems... the boat dont have a bilge pump, and i do live @ lake so i would like to live the boat in the water, but almost every week i have to take it out to drain the water...i try to install a pump, but there is no access under the boat, what should i do?
Old 04-22-2009, 06:34 PM
alan white's Avatar
Rep: 1168 Posts: 3,270
The back of the boat is where to put it, since without people in it the boat will always sit lowest there. under the splash well, far back as possible. Get an automatic one. It will turn on every few minutes and if there's no water, it will turn off, if water, it will remove it through a hose (you will have to buy) over into the splash well where it will drain out. One wire goes to the battery ground and one to a switch (or directly to the battery positive post) and it must have at least an inline fuse (it will say what size fuse in the directions). It shouldn't tax the battery too much. Leave it with a good charge in the battery though. You will have to crimp eyes onto the wire ends sized to the battery posts, available at a marine supply. maybe they will crimp them on for you for nothing.
Old 04-22-2009, 07:53 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1918 Posts: 4,113
A few more bilge pump points of interest:
* Don't count on the pump actually moving more than 50% of its claimed flow rate, once the outlet hose, a bit of gunk on the intake strainer, etc. is considered
* If you forget to put a 3/4" drain plug in, once it's 16" underwater it will let in about 420 gph, more as the boat sinks deeper
* If a 1.5" through-hull breaks at 16" below water, it'll let in closer to 1700 gph
* A wave breaking over a 6' wide transom might bring 40+ gallons of water; how long would you want that water in the boat before it's all pumped out?
The standard little discount-bin 600 gph pump (you know, the little plastic one the size of a coffee mug) can handle a rainstorm, but not much more. Look for something beefy enough to make you comfortable with the numbers above.
If you can't get to the bilge, it shouldn't be too hard to take a jigsaw or a big hole saw to cut an access port in the sole.
Old 04-22-2009, 09:27 PM
Rep: 10 Posts: 2
ok thats the thing, i dont any idea where should i cut the hole...should i cut biger enough to fit the pump? and where?
another thing, i dont know if anyone is familiar with the slickcraft, but this boat has 3 plugs holes, one on the botton, that you can take with a screw driver, a other one maybe 3 inches on top ( that leads to inside where is the gas tank, where i do have acess) and the last one is locate inside where the gas tank is, but its seems to go inside the hull....
any ideas?
Bilge pump suggestion requested 3rdbase Sailboats 6 11-08-2007 11:38 PM
Bilge pump wiring dereksireci Electrical Systems 4 08-09-2007 06:50 PM
Bilge Pump Activity Monitor odysseyII Electrical Systems 4 11-11-2005 06:21 AM
bilge Pump monitor odyssey11 Marketplace 0 10-24-2005 07:05 AM
Bilge Pump Protection tony.young Electrical Systems 16 02-22-2005 08:41 AM
