#76
| Gee, I cant remember the original posters name ? At any rate...read Eds description of how an alternator works.. specifically how an alternator senses the state of the battery to determine how much output it supplies and you will find your answer. |
#77
| Nice to be asked !! yes a good idea and one I had not thought of ...if you have a very big house bank well run down then it could be a while before the strting battery comes in . as you say starting typically only needs about 0.2 AH or less so you got lots of starts in your battery !! Its easy to up the voltage regulator setting but less easy to drop it . But if we are only talking a 50 A alternator here a big diode in the feed line would drop it 0.7v And NO lamiaspaska you cannot drop the volts with a long lead thats a resistor and when the charge current drops to zero so will the voltage drop ... The 12 v doctor information has far too much information for most people to absorb ( the Zener diode in dia 61 is in the wrong place) and the only dual battery system shown is a very dated 1970 dual diode solution ..great reading/reference for an auto electrician though.... |
#78
| Throttle control and a amp meter is a simple answer for the question originally asked. Just my thoughts, Mike |
#79
| bookmark for future read great thread tho cheers
__________________ I am skeptical of the deniers diatribe |
| How do you see if alternator is charging? | mr300s | Powerboats | 7 | 07-15-2006 09:54 PM |
| charging problem in evenrude 100hp (66 model) | tojulio | Outboards | 0 | 07-05-2006 10:10 AM |
| what will the differantial do whilst charging down the river? | Volksliner | DIY Marinizing | 8 | 05-28-2005 02:28 PM |
| What will the differential do whilst charging down the river | Volksliner | Boat Design | 1 | 01-08-2005 09:20 AM |
| No Limit reached limit | Dutch Peter | Boat Design | 16 | 09-09-2004 07:20 AM |
