Old 09-21-2010, 02:27 AM
jfkal jfkal is offline
Rep: 10 Posts: 9
Honda EU20I and aircon. field experience
I am contemplating the Honda Genny to run my boat aricon. Honda is tight lipped with advice and wont loan me one to test. Is there anyone who is successfully running an aircon from it? I am naturally concerned about the starting current capability.
Old 09-21-2010, 02:32 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
...I have a Honda 2000, one of the new type, it will start up at least twice its running capability no worries, it does not however actually run full time 2000watts, it is 1800 if you read the brochure
Old 09-21-2010, 02:44 AM
Rep: 10 Posts: 9
Yep. I saw that 1800 caveat. Have you tried an airconditioner from it?
Old 09-21-2010, 08:52 AM
Tug Tug is offline
Rep: 119 Posts: 51
They are a sweet generators i have used one fro running tools at work..
But the best thing about them is
"At the flick of a switch this feature only runs the engine as fast as the load demands"
Thats an expensive feature when its not needed for running a large load..
But great for intermittent loads...tools..
Cheers
Tug
Some days it feels like im holding together a fraying rope....other days are worse...
Old 09-21-2010, 03:56 PM
Landlubber's Avatar
...no sorry, never ran an air con, but have run a deep freeze and two domestic fridges at the same time and allowed them to start the same too.
Old 09-21-2010, 05:57 PM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
We're planning on doing the exact same thing. My research has shown an EU2000i should be able to handle a 9000BTU A/C with no problems. You just have to be careful which other AC loads the Admiral decides to throw on while the A/C is running!
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 09-21-2010, 06:23 PM
Landlubber's Avatar
...I would not expect that anything else could be used at the same time as a 9000btu air con mate.
Old 09-21-2010, 07:00 PM
CatBuilder CatBuilder is offline
Rep: 1316 Posts: 3,040
This is correct.
The 9000 BTU AC should have a capacitor as well to help with the initial load.
I am currently running a Honda EU2000i with 9000BTU Coleman Polar Cub RV-style, roof mount air conditioner. It has a built in capacitor to help with the startup, but it's still close to what the EU2000i can handle on startup, even with the capacitor. If you try to start a huge air conditioner, overload it and end up with low voltage to your compressor, it can cause damage to the compressor, so be careful.
When the thing settles down and runs, the EU2000i seems to run at about 2/3 capacity with the compressor on.
WARNING: When you stop even a 9000btu AC, then restart it too soon, it will overpower the EU2000i.
Kurt Hughes was right about this place.
Old 09-21-2010, 07:01 PM
This is mostly correct. You certainly can't start a battery charger or microwave, but you can easily run a Norcold refrigerator in 110VAC mode, plus a laptop and cell phone chargers.
Old 09-21-2010, 07:30 PM
jonr jonr is offline
Rep: 34 Posts: 246
It my experience, the starting load created by a motor and compressor is highly variable depending on the exact model used - could be 2x and could be 6x. An inverter based AC unit (or microwave or battery charger) should have very low starting load.
Old 10-15-2010, 01:24 AM
SeaJay SeaJay is offline
Rep: 112 Posts: 211
I'm using a 2000i as my primary power source for my build. Powers 25 CFLs and my smaller power tools. (I've got a larger generator for the biger tools, but the hourly use is easily 10 to 1 in favor of the Honda)
The "Eco Power" mode just sips gas and is very quiet. I'm so impressed with this thing that I'm going forget about a diesel genset and just go with the Honda...as someone once said, "once you've got the gas on board for the dingy, you've already crossed that Rubicon". I agree.
What I plan to do for AC is here in this white paper...
http://www.victronenergy.com/upload/...paper%20GB.pdf
Calder has been writing about this for the last year or so and I think it has lots of merit.
Regards,
SeaJay
Old 10-20-2010, 06:43 AM
Rep: 756 Posts: 3,328
Some folks use RV roof mounted units for air cond.
There is a HUGE selection in terms of starting and running amps.
The easy start option exists because many camp grounds suffer from low (barely 100V) voltage , and should be useful for a smaller boat noisemaker.
FF
Info on NA field??? Lle Education 6 01-20-2010 03:26 PM
Marine field publications Scott Carter Boatbuilding 0 12-09-2009 10:39 PM
Marine field periodicals Scott Carter Boat Design 0 12-09-2009 10:37 PM
Honda 9.9/15/20 LinedTheBlind Outboards 2 05-09-2007 07:03 PM
Naval Architect Fresh Graduate With Training Experience And Consultancy Experience anoop21 Services & Employment 0 07-10-2004 11:44 AM
