| High Volume dc reversing ballast pump We are looking for a high volume (25gpm) reversing, DC ballast pump to be used in our Multi-hull. I have not been able to find one as yet. If need be we might be able to work with a hydraulic run pump. Must be salt water duty, does not need to draw to a head and not much of pump head (6ft) dry running would be a plus but not required. Any suggestions. |
| Only pumps with neoprene impellers, like PAR and Johnson, can work in both directions, although switching direction is a large burden for the impeller, especially if no fluid is present. It is better to use two non-contact water pumps with non-return valves.
| Thank you that was my assumption, I thought I'd try the fourm to see if there was something out there that I had not run across. These pumps will be in a very harsh environment anyway (oil skimmer vessel) so it will be better to plumb them individually. Thank you again for you contribution. |
| Incredible prop shaft driven bilge pump - Amazing volume pumped | yachtwork | Marketplace | 1 | 03-28-2010 11:57 AM |
| Susuki-high Pressure Fuel Pump | ProLine86 | Outboards | 0 | 07-21-2009 08:41 AM |
| Watermaker without a high pressure pump | GoSlow | Sailboats | 6 | 12-08-2008 01:38 AM |
| Reversing reverse?? | jimisbell | Inboards | 22 | 10-15-2006 02:12 PM |
| Volume of a Half-Diamond For Hull Volume Displacement | Free Pirate | Boat Design | 2 | 03-11-2005 03:24 AM |
