Old 11-25-2011, 11:15 AM
Rep: 670 Posts: 2,457
Sure...Ive got a 24v 1500 amp battery bank. What is an automatic battery cell monitoring system ...how does it work...heat sensors ?
Old 11-25-2011, 02:07 PM
Rep: 1758 Posts: 1,561
Different cell types and system requirements have different sensors but generaly temp, electrolyte level, s.g., present voltage, present amp draw, % charge, Ah left, H2 levels, are all things that are monitored. There is a fairly wide variety of systems out there from those for computer backup lithium cells to electric car systems, to 1MW submarine wet cell stacks (which is where the copper bus bar and an axe comment comes from). Just google "automatic battery cell monitoring system"
Old 11-29-2011, 07:44 PM
cyclops2 cyclops2 is offline
Rep: 94 Posts: 234
Well
A QP 20 or 30 amp household circuit breaker, ranges from 5,000 to 10,000 interrupting amps. Home Despot & Lowes
Old 11-29-2011, 08:30 PM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
That may be an Alternating Current only rating. Battery banks on boats are Direct Current. Interupt ratings are frequently higher for AC than for DC because with AC the current goes to zero twice every cycle.
David Cockey
Old 11-29-2011, 11:06 PM
Rep: 94 Posts: 234
Does this help ?
Grainger.com sells the Schneider Electric Company line of DC circuit breakers that are rated for 10,000 amps DC interrupting capacity, with adjustable high & low trip points.
Old 11-29-2011, 11:14 PM
Rep: 94 Posts: 234
Square D had their QO breakers rated in both AC & DC.
To be fail safe with DC batteries.
ALWAYS put in a fuse. They never have a bad day.
When you are unsure. ALWAYS put in a fuse.
Old 11-29-2011, 11:22 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Thanks all... will look into it further.....
Personally, I couldn't see the problem with a T fuse.... but I was asked the question and I hadn't looked into such larger interrupt capacity breakers before....
Will
Imaginocean Yacht Design
www.imaginocean.net
DC circuit in aluminium boats Mat-C OnBoard Electronics & Controls 5 09-13-2011 12:58 AM
Simplest possible circuit needed please L'eau.Life OnBoard Electronics & Controls 6 02-08-2010 02:36 AM
Mooring Force & Winch Capacity calculation ociship Boat Design 4 12-07-2009 07:03 PM
Circuit Design Software dfmoss OnBoard Electronics & Controls 7 06-18-2008 01:38 PM
Short circuit mikep Electrical Systems 1 03-27-2007 09:15 AM
