Old 11-20-2011, 10:18 AM
jollyricard jollyricard is offline
Rep: 10 Posts: 73
HELP!!!-Earthing
DEAR ALL,
HOW CAN I ESTABLISH THE EARTHING SYSTEM ON BOARD SHIP?
WHAT ARE THE REASONING TO DO?
many thanks in advance
best regards
Old 11-20-2011, 10:32 AM
Rep: 670 Posts: 2,457
Aww Jeez....a new...EARTH SYSTEM ????
Ground control to Major Tom...
Ground Control to Major Tom....
take your protien pills and put your Helment on....EARTH. ????..
Ground control to major Tom.... come in Major Tom..Come in.......
Old 11-20-2011, 11:17 AM
Rep: 1493 Posts: 7,447
Are you asking about AC, DC or bonding?
Old 12-04-2011, 10:37 AM
Rep: 10 Posts: 73
Re
Dear Gonzo,
many thanks for answer;
yes, I am asking you info for AC,DC e bonding( onboard ships);
thank you so much!!!!
Old 12-04-2011, 03:53 PM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Here is your answer: http://www.earth2.net/parts/basics/milstd1310g.pdf
Hoyt
Old 12-04-2011, 05:54 PM
Are you trying to comply with a rule?
Old 12-04-2011, 07:43 PM
cyclops2 cyclops2 is offline
Rep: 94 Posts: 234
Size, type & material of the ship ? Salt water or both, salt & fresh water ?
Old 12-04-2011, 07:58 PM
Rep: 94 Posts: 234
Found the company.
look up www.mgduff.co.uk
They have loads of very good papers covering anything that attacks any type of boat / ship.
Old 12-05-2011, 02:05 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
In very, very global terms: to avoid voltage differentials. A bird can sit happily on a wire carrying 250.000 volts, but if it had really long legs and could put one foot on the ground, it would go up in smoke.
Tons of info in this forum, use the Search function.
Old 12-05-2011, 07:33 AM
Rep: 94 Posts: 234
This site does have engineers dealing with ship earthing problems.
I always preferred a " Y " system with the center connection as the ground. It will not tolerate a second voltage as a grounding. I go back in electric power about 53 years.
People first. Repair any phase that is starting to lose full insulation to ground.
With todays many different current sensing equipment. ANY VERY SAFE SYSTEM is possible.
HELP!!!-Earthing-earthing-ships.-1.jpg  HELP!!!-Earthing-earthing-ships.-2.jpg
Old 12-05-2011, 08:08 AM
Rep: 94 Posts: 234
As a observation to safety in tankers & grounding.
The tanker shipping industry is CHEAP. To allow a ungrounded system in a all metal structure is VERY VERY DANGEROUS to anything that wants to stay alive.
Try to pull that stunt in a metal mobile trailer. Pure risking peoples safety by most USA electrical codes.
GREEDY GREEDY oil tanker ship owners. RUN A DAMM full ground to all pieces of any energized equipment !!!!!!!!!!!!!!!!!!!!!!! That code Is HOPEFULLY NOT ALLOWED on any ship transporting Gasoline, Naptha, Natural gas, Propane.
Anything to make a bigger profit with a known dangerous piece of old equipment.
"Cost us money to wire the ship correctly."
Old 12-10-2011, 07:25 PM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
all the 24v electronics on a ship have isolated negative side ( floating earth) that is supplied via the UPS's or batteries
The cases of the equipment are grounded to the hull
Much of the equipment will flag an error if they sense the ground and the negative have a connection
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 01-05-2012, 02:20 PM
Rep: 10 Posts: 73
ok, thanks;
Earthing a wooden boat stuhaynes OnBoard Electronics & Controls 17 09-04-2010 10:38 AM
