Old 11-25-2010, 07:00 PM
ChrisN67 ChrisN67 is offline
Rep: 47 Posts: 49
Helm Switch Layout and wiring
Anyone out there have any experience on the wiring of high current loads Like drive trim and trim tab motors? What initiates power to the? The main battery switch? I was thinking about having a fuse block for those types of loads powered from a powered relay triggered from a diode input from either "engine "On" key position.
I am using the Cole Hersee MiniBuss System and it is very compact and simple to use. Saves wire and time.
Old 11-25-2010, 10:30 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Chris, The trim tabs have relays at the pump, so there is no need for any fancy setup.
What do you mean by a powered relay triggered from a diode input....why complicate a simple system. If your needs for current are high, simply switch via relays at the units, that way the switches can be lighter and the power supply to the relays (and out of course) is the only heavy wires.
Old 11-26-2010, 12:03 AM
Rep: 3125 Posts: 9,399
I'll ditto what Lubber has touched on, why make relatively simple circuits more complex? Maybe it would be helpful if you offer a reference or context point to clarify the requirement.
Old 11-26-2010, 02:50 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
That is the way to do it if the current requirements exceed the rating of the key switches. If that is not the case (it seldom is), you just power a terminal block with diodes from each key switch. With ordinary 1N540X types you have 3 Amps, enough for a dozen power relays and instruments.
The relay + contacts are wired to the main battery switch.
Wiring a start switch Arkman Electrical Systems 11 07-02-2010 07:38 PM
Stop Switch PatrickShannon Electrical Systems 1 03-06-2009 08:12 PM
Layout dick stave General Computing 14 12-17-2008 11:51 PM
74 Chrysler 555HG Ign. Switch wiring Charles 563 OnBoard Electronics & Controls 3 02-16-2008 01:30 PM
Ignition Switch Wiring???? bgull2 Outboards 0 05-29-2006 03:14 PM
