| generator/genset advise wanting to hook up a power system for running 240v appliances on demand of when i need it, i will be powering a minimum use like microwave , maybe other small appliances when i need to cook etc, but aim to run 12 v lighting and tv etc so can power this thru batteries, so generally i need a remote style system that i can start and stop from my cabin area for when i want to run the 240v or charge the batteries . what is the diference between a generator and a genset, can a normal generetor like a 5kw petrol unit that is electric start be used and plum the exhaust outlet thru hull etc or is there a problem with these style of units(apart from noise) in a boat, my boat is ali catamaran so dont really have a worry about the noise as it will be put into one of the hulls that are sealed from the cabin, and at most it will run for maybe 1 hr aprox for cooking time any experiences in diy fairly low budget setups would be helpfull, even the ones that didnt work to know from experience would be great... |
| There is no difference between generator / genset in common use of language. Of course you could use a petrol genset with a dry exhaust, though that might be finicky to build on a smaller cat hull. You have to be sure that there will never get water into it when sailing. And of course you need a special ventilation (ex. proof ventilator) for the room. It maybe the better solution just to install a larger alternator on one main engine and a inverter. Regards Richard |
If being able to cook on demand is your main concern install a cng/lpg system. Flip a switch at the galley to turn the gas on turn it off when you are done. This assumes a proper installation with a dedicated sealed locker and other appropriate features. |
| 12 Volt DC Vs. AC Genset | ChrisN67 | OnBoard Electronics & Controls | 7 | 02-22-2009 03:49 PM |
| DC / AC Genset | captainjsw | OnBoard Electronics & Controls | 2 | 11-23-2008 11:12 AM |
| Multi Genset DE system | robbieroneill | Hybrid | 8 | 08-06-2006 03:11 AM |
| New Genset Woes - Who To Advise re Design Defect? | elmaceh | Open Discussion: All Things Boats & Boating | 8 | 04-21-2006 07:26 AM |
| Hybrid - Genset-Inverter | Charlie-Papa | Boat Design | 3 | 07-23-2005 11:57 AM |
