Old 09-11-2011, 04:03 PM
goboatingnow goboatingnow is offline
Rep: 74 Posts: 65
Originally Posted by CDK View Post
Not quite true Dave.
I don't know about Ireland, but standard installation material in Germany and surrounding countries is rated at 250V/15 amps for sockets and 10 amps for switches, but the most popular 3-wire cable is only 1.5mm sq.
A few years ago that was still 2.5mm sq., the price of copper caused a major shift there.
Of course the heavier wires like 2.5 and 4.0 are still available but demand has dropped considerably.
Domestic practice in the UK and Ireland is ring based ( 40 amp) and mains sockets typically use 4 sq. Uk boats have tended to follow that. My Bene is 2.5 sq stranded.
Rewiring a boat is a horrendous task. Lots of wires are buried grp conduits and are impossible to remove. What I said was that it behoves an inspection. If the cabling is adaquate then it could be used. The " pull it out" without examination is a brainless thi g to do.
In fact I'd go further. Even if I discovered lighter cable. I would derate my breakers and live with the lower powered sockets. Even 10 or 12 amps at 110 is still a reasonable socket. I'd then selectively rewire the high powered stuff, like water heaters, etc.
Dave
European rules for a small boat builder... Grant Nelson Boat Design 5 06-30-2011 03:52 PM
European boat diesel ventilation RoyHB Diesel Engines 16 06-13-2011 08:29 AM
Electric European Canal Boat captainyoung Boat Design 15 05-24-2011 03:22 PM
Spec. Boat gmeadows Wooden Boat Building and Restoration 2 08-14-2004 07:55 PM
Buying a boat for ICW and Bahamas run; advise on quality/min spec please kattz Powerboats 2 08-01-2004 10:54 AM
