Old 03-20-2010, 08:30 PM
sportfisher sportfisher is offline
Rep: 10 Posts: 7
Electrical problem-need advice
I opened my boat for the season today and found an electrical problem.
I turned on the AM/FM stereo, VHF, GPS and auto pilot (on once i turn boat on the auto pilot goes on). Everything runs fine......here is the problem;
1- once I squeeze the VHF mic, all the electronics turn off and on.
2 - if i ENGAGE the auto-pilot, all the electronics flash off and on.
Can anyone give me advice on where to start trouble shooting?
Thanks - Joe
Old 03-21-2010, 02:51 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
You have at least one corroded junction. The equipment you listen doesn't draw much current so they are supplied from a common terminal block or connector.
Pressing the transmit button causes the current to the VHF to increase 10-fold; due to a corroded contact the voltage collapses at that moment.
It may very well be that the bad spot is not in the +12V circuit but in the return (ground). There probably is a common ground terminal located near the equipment. How that is physically done depends on the preferences of the electrician who installed it: it can be a row of screw terminals or contact lugs. Some use a single long screw on which all the cable eyes are stacked.
Once you have access to the wiring you probably can see the problem without measuring any voltages or currents because the contact place shows green corrosion products.
Old 03-21-2010, 05:52 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Hi sportfisher,
Reckon CDK has just about solved the problem as so many pieces of gear are attached, what he says makes real good sense
Old 03-21-2010, 05:05 PM
Rep: 10 Posts: 7
Thanks guys, i will be taking a look this week and will start with the ground connections. Could a connection be loose and not corroded? because when i was under the console last season the bus terminals looked like new, i guess i will see.
Thanks again, i will let you know
-Joe
Old 03-21-2010, 06:48 PM
Landlubber's Avatar
Yes, ther often become loose, especially boats that have to be shipped from thhe original maker, we regularly have to go over the whole boats electrical connections and tighten em up. Have fun, and be very methodical, do not assume that anything is tight.
Help!! Need Advice With Aluminum Welding Problem bobk Metal Boat Building 10 04-25-2009 06:48 PM
Electrical problem on a 4W Freedom 160 shotgunsmitty Electrical Systems 27 06-19-2006 11:14 AM
electrical mrtywatz Powerboats 2 06-18-2006 06:30 AM
electrical problem gasdok007 Metal Boat Building 5 04-17-2006 04:19 AM
electrical Electrical Systems 5 02-12-2003 12:39 PM
