Old 09-04-2010, 09:52 AM
Wavewacker Wavewacker is offline
Rep: 136 Posts: 421
Thanks for the posts. So, if one were to build a small wooden boat, my definition of small is 10' to 30', would you incorporate a steel strip along the keel bringing it above to the deck, to serve two purposes, one as the common ground and to protect the keel?
Old 09-04-2010, 10:25 AM
Ike's Avatar
Ike Ike is offline
Rep: 1356 Posts: 1,371
I would ask, how complex an electrical system? If it's just running the engine and Nav lights, no. If you start adding things like interior lighting, refrigerator, radios, GPS, and on and on then yes. If you bring Alternating Current aboard then definitely yes. Also you said keel? Is this a sailboat with lead or iron? then it is a yes . If it is a powerboat with a wood or fiberglass keel, no metal then no. (may seem obvious but I've seen some strange things.)
A 10 to 20 foot boat. I can't imagine why. A 20 foot to 30 maybe. As I said, it depends on the complexity of the electrical system.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 09-04-2010, 10:38 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
I would use stainless instead of steel because it'll live longer and connect it to the negative pole of the DC wiring. In case there is any AC wiring, I would also use it as protective ground. The AC neutral must stay isolated.
wooden boat liamoshay Wooden Boat Building and Restoration 7 01-03-2011 05:40 AM
Third world wooden boat boat-yards? atavist Wooden Boat Building and Restoration 38 03-09-2010 11:37 AM
Wooden Boat shakeyj Wooden Boat Building and Restoration 76 06-10-2006 11:13 PM
wooden boat texasboatbuild Wooden Boat Building and Restoration 6 05-09-2006 04:42 PM
Wooden boat Boatbuilding 1 12-03-2001 12:30 AM
