Old 12-26-2007, 07:11 PM
cbaysailor cbaysailor is offline
Rep: 10 Posts: 2
Dual dock power input 120/240
I currently have a 240vac 50a input to my boat.
Would like to add alternate 120vac 20a or 30a input, for occasional cases where 240 vac might not be convenient. This would be wired through an A/B breaker that would replace a single breaker within 10' of the genset.
I know enough to not plug in both dock lines at the same time or draw from two sources at the same time, but are there any physical interlocks needed in addition to the two A/B switches on the boat which allow only one of the 3 sources (120 line, 120 genset or 240 line) to be used at the same time?
Thanks
cbaysailor
Old 12-27-2007, 08:19 AM
Auspicious Auspicious is offline
Consider using an adapter instead. West Marine has a nice chart of the alternatives. A 30A 125V to 50A 125/250V adapter will allow you to use your current shore power cord up to the power pylon where you can fit the adapter. Less work, less gear to carry, less chance of error ...
Four Winns 240 Horizon hull design - porposing DaleG Powerboats 2 12-12-2007 07:35 PM
120 mercruser to 4.3L OMC flounder Inboards 0 09-11-2007 10:39 PM
Input on PWC powerplant as aux. power for sailboat. LP Sailboats 3 09-10-2007 08:49 PM
Mercury 240 HP EFI 3Cyl V6 Motor Required toolm8kr Powerboats 0 07-07-2006 12:59 PM
Mercruiser 120 Replacement penguin Propulsion 1 04-23-2005 10:03 PM
