Old 03-02-2008, 04:39 PM
lunatic lunatic is offline
Rep: 28 Posts: 77
DIY marine metals corrosion meter
Solder small pencil zinc, without threaded brass adapter, commonly found in marine engine cooling systems, to flexible insulated wire, flexibility over gauge, only milliamps here, lenght appropriate to geometry of use. Seal with epoxy, need only 1/4 inch of exposed metal to clean off any corrosion from use and storage, this end is immersed in sea water. Connect other end to negative lead of small cheap digital multimeter and its positive lead to clean metal of boat. For steel millivolts readings of 0 to 200 good ,below 0 over protected, obove 200 you have problems. In expensive and less sensitive analogue corrosion meters this is "freely eroding"
Inactive zincs can result from poorly conducting connections or an insulating scale from either oxidation and or marine growth, stiff wire brush will solve the latter, hammer often the former. There are many myths of both natural and induced corrosion so be very skeptical of any diagnostic opinions and test them with the meter. The theory behind all this lies in the fuzzy world of the electron, a thead someone else should start.
Mixing metals underwater fisherJim Boat Design 16 10-02-2007 08:57 AM
...carbon / metals connections... fradrigo Fiberglass and Composite Boat Building 0 07-13-2007 10:15 AM
metals,steels Redsky Materials 15 07-27-2006 03:38 AM
When did metals lose the high-tech edge? MarkC Metal Boat Building 29 07-22-2006 03:35 AM
Nice 11 meter DIY aluminum boat. Victor Möller Metal Boat Building 1 08-15-2005 12:35 AM
