Old 11-07-2007, 08:58 AM
TerryKing's Avatar
TerryKing TerryKing is offline
On the Red Sea!
Rep: 278 Posts: 581
Location: King Abdullah University of Science & Technology - Near Jeddah, Saudi Arabia
Discussion- Multipurpose Onboard Computers: Monitoring and Control of Onboard Systems
Note: This thread is a branch from the ongoing "Discussion- Multipurpose Onboard Computers" Please comment, add, critique etc.!!
THIS MAY INCLUDE MONITORING AND CONTROL OF THESE ONBOARD SYSTEMS:
  • Propulsion and steering systems
  • Sail Rigging Monitoring and Control
  • Onboard power systems
  • Consumeables / Tank Levels
  • Heating/cooling
  • Lighting
  • Water/sanitation systems
  • Environmental and weather instruments
  • Safety/Security Monitoring: Intrusion, Bilge Flooding, Heat/Fire, Dangerous Gases, Anchor Drag
CHALLENGES:
  • DEVICES: Simple, Reliable onboard system monitoring and control devices
  • SENSORS: Interface to wide variety of sensors for: Engine, Power Systems, Tanks, Heating-Cooling, Weather, Environment, Gases, Safety etc.
  • INTEROPERABLE: With industry-standard NMEA devices
  • CONTROLS: Effective, affordable controls and switches for onboard systems, lights, etc.
  • AVAILABILITY: Reliable in heat, vibration, voltage variations, (possibly Lightning)
IDEAS AND DIRECTIONS:
  • MONITORING DEVICES: Use Industry Standard (ex: CruzPro) Engine and Power Monitoring devices with NMEA0183 outputs, or Microcomputer-based DIY or Custom devices.
  • NMEA COMBINERS (MULTIPLEXERS): Industry Standard or DIY/Custom devices. Monitoring devices could/should include NMEA Multiplexer capability, of 1 to 4 other devices. A final NMEA Multiplexer should have USB output to computer.
  • NETWORK: (See Network Thread): NMEA0183 (Serial 4800 Baud), may be implemented as Fiber Optic or Wireless link instead of wired.
  • CONTROLS: NMEA controlled "Smart Switches" with on-off, Status, Current measurement, Overcurrent and overvoltage protection, automatic try-again on overcurrent, etc.
  • CONTROLS: Lighting controls for Halogen or LEDs, with dimming, status readback, current measurement capability. Perhaps include human-detect lighting (at least for the head)
Regards, Terry King ...On the Red Sea at KAUST
Old 11-07-2007, 09:13 AM
TerryKing's Avatar
On the Red Sea!
Rep: 278 Posts: 581
Other Contributors.. please check in!
Some of the people who contributed to this subject in the past were:
  • TimB: Rigging Loads, "Friend developing Monitoring and Control Units",
  • Hank Rosendale: Systems Monitoring
  • TerryKing: Smart Switches
  • SAE140: Networks, Microcomputers
This was on a quick look through the thread, not a Hollywood-Legal set of credits, so please don't beat me up if I missed you! Just jump in and comment/suggest/critique.
Old 11-07-2007, 09:46 PM
TerryKing's Avatar
On the Red Sea!
Rep: 278 Posts: 581
Placeholder 1
temporary
Old 11-07-2007, 11:12 PM
TerryKing's Avatar
On the Red Sea!
Rep: 278 Posts: 581
INFORMATION about MONITORING of onboard systems
This is a try at a list of the onboard systems that may be MONITORED. Please comment, add, suggest, critique!
These have outputs that can be read in, displayed, logged, and later retrieved. "Meta-Data" such as averages, Max/Min, trends and graphs can be created and displayed from logged data.
- Engine Monitors: Commercial or DIY box that senses engine variables:
  • Temperatures: inlet,block,outlet, exhaust riser, turbo, oil, drive system, alternator.
  • Pressures: Oil, Fuel, Coolant, Turbo, Hydraulic pump.
  • Electrical: Alternator current, voltage, EFI supply voltage
  • Vibration: Engine, Drive system
- Power Monitors: Commercial or DIY box that senses AC and DC Power systems:
  • Voltages and Currents: Batteries, DC Alternator / Generator outputs, Wind/Solar system outputs
  • Voltages and Currents: AC power systems, Shore power, Generators, Inverters. Load current from onboard devices or circuits
  • Status: Loads which are using power. Circuits whose overcurrent protection has tripped. Circuits that are off/disabled.
- Consumables/Tanks:
  • Fluid levels: Fuel tanks, fresh water tanks, gray and black water tanks
-Heat/Cooling Monitor:
  • Status of cooling or heating devices
  • Temperatures: cabin/crew/engine room/helm/Refrigerators/Freezers
-Weather Instruments
  • Wind Direction and Velocity
  • Barometric Pressure
  • Rain Detector
  • Snow Depth (For those wintering-over at Bar Harbor)
- Environmental Monitor:
  • Air temperature: Outdoor, Cabin/Crew areas, Engine Room,helm
  • Water Temperature: Sea water, fresh water, hot water
  • Lightning Detector
-Bilge/Pumps Monitor:
  • Each Bilge Area: Water level, Pump Running Status, Pump Current
-Fire/Gases Monitor:
  • Detect explosive gases, combustion products, CO, fuel vapors, solvents in Engine Room areas and bilges.
  • Detect Gases, CO, combustion products in crew areas
  • Detect overtemperatures in various areas (may be combined with Environmental)
Old 11-07-2007, 11:16 PM
TerryKing's Avatar
On the Red Sea!
Rep: 278 Posts: 581
INFORMATION about CONTROL of onboard systems
**under construction**
Discussion- Multi-purpose Onboard Computers TerryKing OnBoard Electronics & Controls 173 02-09-2009 05:28 PM
Discussion- Multipurpose Onboard Computers: Human Inputs - Human Outputs TerryKing OnBoard Electronics & Controls 6 12-04-2007 08:51 AM
Discussion- Multipurpose Onboard Computers: Computer System Units - power - cooling TerryKing OnBoard Electronics & Controls 11 11-14-2007 10:00 PM
Onboard Computers TerryKing Wiki 38 05-26-2007 06:39 AM
Where should we discuss onboard computers? TerryKing Forum Questions and Suggestions 17 03-16-2007 11:30 AM
