Old 12-17-2011, 07:18 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
De sulphator ..any good
doin some research for another forum and came across these ..now always thought if a 1 week connection to a charger wont bring it back its dead.
What these modern devices are doing is charging two capacitors in parallel across the battery and then the electronics puts them in series giveing a 24v pusle to the the battery.....a bit like the old idea of using half wave rectified ac to charge a battery ...very pulsey....
I also see companies setting up to do regular de sulphation on a commercial basis for fork lifts etc so is there something in it ...???/
Old 12-17-2011, 08:19 PM
Yobarnacle's Avatar
Yobarnacle Yobarnacle is offline
Rep: 546 Posts: 516
There is a fellow on net selling "China Powder" to desulphate batteries. He also sells franchises and you can buy "China Powder" in bulk from him and become a millionaire entrepeneur selling the powder or servicing companies with fleets of electric forktrucks....yada yada yada...
I believe "China Powder" is magnesium sulphate. Also known as heptahydrate epsomite (MgSO4·7H2O), commonly called Epsom salt.
De-sulphating batteries with epsom salt is an old trick from early 1900s, 1950s.
Mix half a cup epsom salt into a liter of boiling water. Stir till dissolved.
Add 3 tablespoons of epsom salt solution to each sulphated cell in dead battery. Check battery with hygrometer. Treat only dead cells.
Charge for 2 days. Agitate while charging. Requires frequent shaking of battery, or, sit battery on a board resting on a large speaker. Play 1960s acid rock or other heavy bass music. Or do as I do. Buy an orbital finish sander and a pack of velcro backed sanding sheets for it. Glue a sanding sheets grit side to back of battery. Place battery on old bed springs or on a web of shock cord so it can jiggle. Attach orbital sander to velcroed sanding sheet glued on battery. Hook up charger and turn on sander to vibrate agitate battery.
Old 12-18-2011, 01:46 AM
pistnbroke's Avatar
I try
I actually meant the electronic version
Old 12-18-2011, 03:03 AM
Yobarnacle's Avatar
Rep: 546 Posts: 516
I know you did. 3lbs box of Epsom salt is about $3 at drug store or pharmacy area of walmart. Would fix about, hmmm, 1000 batteries. How much does the electronic doodad cost?
Old 12-18-2011, 03:07 AM
pistnbroke's Avatar
I try
would not fix a sealed battery and in my opinion woud not fix any batteries ...
Old 12-18-2011, 03:11 AM
Frosty's Avatar
Frosty Frosty is offline
Rep: 1693 Posts: 5,867
West marine advisor had a write up on this a few years ago. They suggested turning everything off and taking the batteries up to 17 and more.
It kinda used to work on the better type batteries in the old days but I dont think new ones appreciate it and are incapable of being resuscitated.
Old 12-18-2011, 03:31 AM
Yobarnacle's Avatar
Rep: 546 Posts: 516
well, I got 20 batteries from the dump for $200, and already had one with a bad cell. Treated all with epsom salt in the dead cells. Ended up with 10 usable batteries, that would produce 12 volts and hold a charge. Paid another $55 to drop off the un-resucitable batteries back at dump. So, 10 batteries for $255 and about a weeks working on them. $25 each fair price?
Old 12-18-2011, 04:31 AM
Yobarnacle's Avatar
Rep: 546 Posts: 516
Here are some links about epsom salts and other additives to repair sulphated batteries. Each instruction differs from what I said and from each other. i also included a link where they said they didn't think it would work.
And I included a link to convert an old lead acid battery to an alkaline battery by dumping the electrolite and refilling with an alum solution. interesting.
there are tons of links about saving batteries. Here are a few.
http://peswiki.com/index.php/OS:Lead...t_Electrolytes
http://www.ehow.com/how_7505036_reco...e-battery.html
http://batteryuniversity.com/learn/article/additives
http://ysuusy.com/Lead_Acid_Car_Battery_Repair.html
negative opinion
http://en.wikipedia.org/wiki/Lead%E2%80%93acid_battery
alum alkaline conversion of lead acid battery
http://blog.hasslberger.com/2007/01/..._acid_bat.html
Old 12-18-2011, 07:42 AM
pistnbroke's Avatar
I try
you are righ Frosty ..in the old days we charged them to 15.3 v on a car and a lot more on the bench ...the idea is to give a pulse of higher voltage which does not cause the battery to heat up or gas ....
but does it work
Old 12-19-2011, 01:17 AM
bertho bertho is offline
bertho
Rep: 45 Posts: 143
Just purchase one of this stuff..as i only use alternator to charge, no sophisticated battery charger with equalization system (sending 15+ volts for some time to clean the plates..)..will see if some improvement??
any have experiences with ?
http://www.sterling-power.com/images...structions.pdf
cheer's
creating and building simple boat is much more difficult than complicated ones.....
Old 12-29-2011, 03:48 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
Buy any top end charger and they are built in these days ( c-tek)
Check out any forklift/golfcart charger, been built in for years.
We have been missing out for years ( me included) from the auto/marine world
http://www.megapulse.net/uploads/media/CSIRO_01.pdf
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 12-29-2011, 05:54 AM
pistnbroke's Avatar
I try
Very interesting but not really conclusive ..like your comment on the marine and auto being left out ...I want it for the 50-60% discharge on the batteries on my electric boat ......do I use it on one and not the other !!!!!
Old 12-29-2011, 07:16 AM
Rep: 1493 Posts: 7,447
$25.00 per battery, plus 4hrs@ $7.25(minimum wager) is $29.00. The total is $54.00 for a questionable battery. I don't see that as a good deal.
Old 12-29-2011, 07:38 AM
pistnbroke's Avatar
I try
Did I miss something gonzo ...?? where /why have these figures appeared ???
Old 12-29-2011, 08:18 AM
it works for any lead acid style battery
Can take months to fully restore as in restore as much as possible or so I am told by people that have tried with half dead batterys
Many fleet owners have them permanenty installed on trucks and buses
looks like a good idea whitepointer23 Boat Design 3 12-17-2011 12:15 AM
What are good boats? atonomy Boat Design 17 03-08-2011 05:41 PM
Looking for a good picture. lewisboats Wooden Boat Building and Restoration 0 01-29-2007 02:07 PM
Looking for a good picture. lewisboats Wooden Boat Building and Restoration 0 01-29-2007 01:26 PM
good websites? emiliaz Fiberglass and Composite Boat Building 2 02-24-2005 04:49 AM
