| Could throttle cable be the culprit? Here's what's going on; I'm getting nothing to the starter. I replaced the starter yesterday. Shifter is in "neutral" position (I have had some issues with it in the past in trying to find that "sweet spot" in order for it to start). Battery is ok. Reset button doesn't appear to be the issue. I do see a draw on the volt gauge when I turn the key completely over as if attempting to start. Where should I begin to look first? Any suggestions or comments would be appreciated. Boat is a '92 Bayliner 1850 Capri 3.0 4 cyl Mercruiser Alpha One sterndrive |
| Check the neutral switch in control if its working OK with tester. Then check the starter relay unit on engine and I suspect this is your problem.
| Stalling under full throttle | JerryIkemire | Powerboats | 3 | 05-28-2008 09:43 PM |
| Honda throttle controls | LinedTheBlind | Outboards | 0 | 05-06-2008 12:11 PM |
| homemade pneumatic throttle help | bballer | OnBoard Electronics & Controls | 1 | 06-06-2007 12:34 AM |
| Off Throttle Steering | pberardi | Boat Design | 5 | 04-21-2006 12:20 PM |
| looking for throttle controls | longngone | Boat Design | 1 | 12-28-2004 07:11 PM |
