Old 01-31-2012, 10:51 AM
cruzahome cruzahome is offline
Converting a power up only windlass to power up and power down.
I have a Plath model 11 windlass that currently only powers up. I want to convert it for power down as well. Any advice would be appreciated.
Old 01-31-2012, 12:08 PM
Rep: 670 Posts: 2,457
I dont know your winch details. Typically You change the rotation of the motor either with a relay for electric winches or relay valve blocks to change oil flow direction if hydraulic.
If electric ... Google it ,and you will find many schematics on the internet . Try googling INSTALLATION MAXWELL or LEWMAR then look for the wiring diagram for reversing solenoid installation . .
Contact Plath to determine the capacity of this DC reversing relay...very much current needed for a winch and haul times can be long .
Old 02-01-2012, 03:35 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
All you have to do is replace the solenoid that came with the winch, install an up/down control box and replace the single switch with a 3-way type.
The control box has 2 cross connected relays inside and is available from many sources. Be sure to buy one with the proper voltage a load capability.
Old 02-01-2012, 05:46 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
does he not need to find out if its a permanent magnet or a wound field type motor first as the reversing methods are slightly different ...???
Old 02-01-2012, 06:54 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Yes, that's right Pistnbroke.
I assumed a magnet type because most small winches have that and the Plath # 11 is for 22-24 ft hulls, but it is not impossible that Plath uses a more expensive wound field motor.
So Cruzahome, exchange the black and red leads to see if the motor changes direction.
If it does not, leave things the way they are or ask an electrician to perform a minor operation on the motor.
I could tell you what's to be done, but since there are again two options and you posted a question no technician would, it's better not to do it yourself.
Old 02-01-2012, 10:10 AM
DCockey DCockey is offline
Engineer
Rep: 1162 Posts: 1,656
Does the windlass freewheel to deploy the anchor? If so you will need to defeat the freewheel system as well as reverse the motor.
David Cockey
Build a power boat, power by wind. PART II windboat Press Releases 34 05-17-2012 09:13 PM
How do you compare electric motor power to diesel power? Yobarnacle Open Discussion: All Things Boats & Boating 114 12-30-2011 04:28 PM
How about a Bloom Box power-cell for main boat power source? Squidly-Diddly Boat Design 1 07-17-2011 07:26 PM
Converting power to sails windLover Boatbuilding 9 03-15-2011 12:55 AM
Converting sail to power Chick Marcoux Boat Design 15 10-27-2003 11:48 PM
