Old 08-10-2012, 10:42 PM
Lawrence101 Lawrence101 is offline
Rep: 10 Posts: 30
Check valve for speedo?
I recently purchased a complete set of Teleflex instrument gauges. I have a question regarding the speedometer pitot tube assembly unit.
The question is, do I need a check valve or ballast between the pick-up device and speedo gauge ?
I read somewhere that water may siphon up into the tube and possibly get into the gauge housing. Does anyone have any idea of this ? or is this just an old fisherman's tale
Lawrence
Old 08-10-2012, 10:50 PM
flyfish flyfish is offline
I've never had a check or antisiphon valve in the speedo tube and have never had any problems. Speedometer is above the water line and my speedometer tube has been fastened up under the gunwale.
Old 08-14-2012, 01:22 PM
Rep: 1732 Posts: 8,377
They work with vacuum so there is no positive pressure. They sometimes have a small restrictor to keep the gauge from jumping.
Old 08-14-2012, 05:39 PM
Petros Petros is offline
Rep: 1260 Posts: 1,774
they actually work by differential pressure, it compares stagnation pressure with free stream pressure across a sealed diaphragm or drum. If you have a check valve in it, the pressure can only go one way, it will build pressure up and not be able to relieve it on the other side of the check valve, the needle will peg and be useless. It not only will not work, you do not want a check valve in the system at all.
Old 08-15-2012, 04:28 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1653 Posts: 2,673
Good thinking Petros!
There will get some water in the tube at speed, but it will never reach the gauge unless it is installed in the bilge.
cogito, ergo sum (Descartes' credo)
Old 08-15-2012, 04:38 AM
Frosty Frosty is offline
Previous Member
Rep: 0 Posts: 0
NO Vacuum --no flow it just compresses the air in the tube --it wont travel more than 3 feet up the tube unless it has a leak at the guage.
Aircraft Pito tubes are identical. Gonzo if you disconnect the pipe on your speedo guage you will get your feet wet.
Suck on the guage and nothing will happen blow and it rises.
Old 08-16-2012, 03:33 AM
pistnbroke's Avatar
I try
Rep: 404 Posts: 1,386
love gonzo
Dont listen to old people. When they die they take all there knowledge with them and leave you to live in ignorance.....
Old 08-20-2012, 08:30 PM
Rep: 10 Posts: 30
Just as i thought, thanks guys for the confirmation.
bulb versus Anti-Siphon valve PatrickS Powerboats 1 06-09-2008 03:15 AM
Spin on a Stainless Ball Valve? AdamFrench Metal Boat Building 5 02-06-2008 12:29 AM
GPS speedo/compass Pascal11 OnBoard Electronics & Controls 1 12-03-2007 07:55 AM
overheating/pressure control valve yousillygoose Outboards 0 07-20-2007 03:27 PM
Rubbing strake / Valve for RIB Marketplace 1 02-28-2004 02:17 AM
