Old 07-01-2007, 11:51 PM
Dirt Cash Dirt Cash is offline
Rep: 10 Posts: 5
Chassis grounding on pontoon.
A friend has a pontoon with a red wire run from the + batt. to the chassis near the motor mount.
Is there any reason the boat chassis needs a + ground?
Is there any reason the chassis needs any "ground" connection to the battery, at all?
Old 07-05-2007, 07:22 PM
redtech redtech is offline
Rep: 22 Posts: 252
first this doesn't sound right
is the motor pos or neg ground
what type of boat and motor
in most cases should not have this pos wire going to the chassis
if neg ground this red wire is more wrong
in most cases the chassis is grounded to help prevent electrolysis
Old 07-05-2007, 08:37 PM
Rep: 10 Posts: 5
Yamaha 4stroke 90. I can only assume...
...the motor is neg. ground but I guess that's really the heart of the question.
It's an older toon that's been repowered by a less-than-professional.
My friend said it was blowing many fuses and her brother disconnected this wire to fix the problem.
I would think it needed to be neg grounded at the chassis but I wondered about the electrolysis issue.
Old 07-06-2007, 12:29 AM
Ike's Avatar
Ike Ike is offline
Rep: 1256 Posts: 1,317
It should be negative ground. It was blowing fuses because you had a direct short to ground.
Ike
New Boatbuilders Home Page
Boat Builder News Blog
My Boating Safety Blog
Old 07-06-2007, 09:49 AM
Rep: 10 Posts: 5
Thanks, but not quite so simple...
...it went all last season with the pos ground hooked up!
I figure something (a light, etc.) shorted the neg to chassis and that's whty it started blowing fuses.
I work in electronics and understand the grounding theory in a car, but my real concern was with a possible link to the electrolysis issue.
To simplify the important question: "Is a NEW toon neg grounded to the chassis?"
I think that is the crux of the issue.
Old 07-06-2007, 10:55 AM
Rep: 22 Posts: 252
dirt cash please don't dig to deep. the toons should not have a pos ground....
this was some what a mistake that got away from a shop
something that is neg is most likely touching the toon now this would not matter if everything was right but unlike cars you don't ground to the chassis and the boat has more none conductive materal than conductive so something like this at time may not be found for years
Old 07-06-2007, 11:01 AM
Rep: 10 Posts: 5
So should she neg ground the chassis or leave it ungrounded?
Old 07-06-2007, 03:44 PM
Rep: 22 Posts: 252
neg ground the chassis and remove that red wire
Old 07-06-2007, 04:09 PM
Rep: 10 Posts: 5
Got it! Thanks a lot!
Grounding the battery when using outboard Scott W Electrical Systems 2 08-26-2006 04:21 AM
Grounding stays and mast? mariner 40 Sailboats 2 06-12-2006 01:58 AM
gas tank grounding acemotorcar Electrical Systems 5 04-17-2006 11:04 AM
Grounding loads... ErikG Boat Design 6 11-03-2003 08:36 AM
Grounding Calculation with Autoship raminb Software 0 12-21-2002 01:28 AM
