Old 08-22-2009, 01:35 PM
B33RND's Avatar
B33RND B33RND is offline
Rep: 10 Posts: 23
Charging batteries without generator or shore power.
Hello,
I am building a 17 meter boat without generator for charging the battery bank of 1000 Ah. The main engine of 200 hp is the only power source and will run 4 to 5 hours daily in which the battery bank need to be charged for the forth coming night. My daily consumption will be 500 Ah when sailing and 250 Ah when not sailing.
My question is if somebody see possibilities how to practically fulfill those requirements and what the objections are...
Thanks in advance,
Berend
Old 08-22-2009, 01:52 PM
WotEver WotEver is offline
Rep: -15 Posts: 33
Hi Berend,
Ideally you'd be looking for 200A (maximum) from your alternator(s), and this would get the bank into acceptance pretty quickly (2.5 hours for 500Ah usage). However, a total running time of 4 to 5 hours would not get them up to 100% charge. That's not unusual, most folk only cycle batteries between 50% and 80% SOC even if they don't realise it.
Here's a (UK) link for some high current alternators: http://www.prestolite.com/pgs_produc...name=4800-4900
Hope that helps,
Regards,
Tony
Old 08-22-2009, 02:51 PM
B33RND's Avatar
Rep: 10 Posts: 23
Hello Tony,
Thanks for your reply. But in that case I'll probably need two pieces of alternators on one engine. Because the maximum amperes of alternators are only 140A/24V as I have seen.
Are there objectives to your approach? Are there other options as well?
Thanks,
Berend
Old 08-22-2009, 04:55 PM
Rep: -15 Posts: 33
Hi again,
That link I gave in my first post showed several 200A 24V alternators.
Other approaches:
1. Ideally, work out how to reduce your consumption
2. If you're still going to be drawing 500Ah then you'd be better off with a 1500Ah battery bank as you'd only drop them to around 70% SOC which would be easier to replenish in your short timescale. You could (should) then add a second 100A alternator.
As a rule of thumb, your maximum charging current should not exceed around 20% of your battery capacity or you risk the chance of damaging the batteries (buckling the plates).
Oh, and you'll need some SERIOUSLY large cables for efficient charging at those currents - 150mm sq or thereabouts. You could use smaller cables (many do) but you'd then HAVE to have a battery sensing alternator controller to counter the voltage drops.
If you have a lot of time to spare and you REALLY want to understand a lot of what's involved in battery charging then check out the techical information at this site.
Regards,
Tony
Old 08-23-2009, 03:37 AM
CDK's Avatar
CDK CDK is offline
experimental engineer
Rep: 1316 Posts: 2,148
B33RND with 500 Ah daily power drain, a capacity of 1000 Ah is a bit small.
Batteries have a much longer service life when cycled between 75 and 100%, unless you install deep cycle types for which you have to pay a lot more.
And what are the objections against mounting a 2nd generator? You could even wire the 2nd to be used only when necessary.
Old 08-23-2009, 04:06 AM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
cdk, I had approx 875 batts on my last
we used only a 75 amp/ht 24vdc alt , was plenty
sailing yacht
of course you would double this for 12 volts
one thing , you probably arer aware of anyway, make sure you load the crank , side loading evenly
then you could have assist wind gen and towed gen, and solar panals etc etc
Old 08-23-2009, 07:35 AM
CDK's Avatar
CDK CDK is offline
sailing yacht
Nothing wrong with that.
But this "B33RND" has something very special in mind because he expects to draw 500 Ah at 24V every night. A lightship perhaps?
Old 08-23-2009, 08:54 AM
Rep: -15 Posts: 33
Desalination plant?
Old 08-24-2009, 03:09 AM
B33RND's Avatar
Rep: 10 Posts: 23
Thanks for the posts guys.
Well, I am just building a average 17 mtr power boat, not a light ship . I am planning to use Traction batteries but, CDK, you are right that either the 1000 Ah battery bank is to less, or my calculation of power consumers is wrong . I think the last is the case. My actual load according my calculation is currently 425 Ah which is also according WHOOSH very much.
May I ask in that regard your idea of power drain from: Radar, AIS (send and receive), GPS and Depth Sounder? All of them are 24 V.
Another question: Is there a difference in power drain of lights of 24V and lights of 220V? And how much power do designers usually count for a average 24V ceiling light?
CDK, the reason I at least want to try without generator is the simplicity of the whole engine room: no generator (often bad quality), no additional dry exhaust (I don't like wet), much less hull penetrations (potential dangers), only one keel cooler, a single power source (so easier electrical installation), fuel polishing, and more of that kind of cons compared to just one single engine.
I am building a seaworthiness boat, and I consider boats with wet exhaust not as very seaworthiness because of the exhaust to close to sea level and the amount of hull penetrations and the potential danger of drowning the engine. Everything is fine as long as the boat will not go deeper than her designed waterline. As soon as that will be the case by some reason at sea, your boat with engine becomes useless and it's the best to disembark .
Thanks in advance ,
Berend
Old 08-24-2009, 03:56 AM
Rep: -15 Posts: 33
Hi again, Berend.
220V lamps will mean an inverter which will have an efficiency (at best) of 95% - so for that reason they'll actually draw more power than 24V lamps for the same light output.
If you can source 24V LEDs they will reduce your power consumption considerably as opposed to incandescent lamps.
As a rule of thumb, CDK was spot on when he said that you should aim for a battery bank 3 times your expected daily usage. It's the same point that I made in Post #4. So once you know your daily usage, you know the size of battery bank. Once you know that, divide by 5 to get the ideal size of alternator(s).
As for all the sea-going questions I won't pretent to know anything about that subject and will allow others to comment
Regards,
Tony
Edit to say that when I wrote "If you can source 24V LEDs" I meant "If you can source 24V LEDs for your fitments". There are plenty of 24V LED lamps around.
Last edited by WotEver : 08-24-2009 at 05:25 AM. Reason: Described above - to add clarity
Old 08-24-2009, 05:35 AM
yipster's Avatar
yipster yipster is online now
Rep: 1027 Posts: 3,270
deep charge bat's nowaday's cost 10/20% more and wouldnt really call that a lot
Old 08-24-2009, 06:20 AM
Rep: -15 Posts: 33
But do you truly get 20% more life out of them? Plenty of folk say no, but I have done no tests myself so can't state either way.
Has anyone got any proof (other than manufacturers' claims) that a deep cycle battery will last longer than a traction battery if never discharged below say 65%?
Old 08-25-2009, 04:20 AM
B33RND's Avatar
Rep: 10 Posts: 23
Yipster, thanks for your comment. Can you motivate it?
Thanks in advance,
Berend
Old 08-25-2009, 07:05 AM
yipster's Avatar
after reading up on the net on deepcycle batts i bought these delphi's after a to heavy, big and expensive mastervolt gel batt turned bad after neglect
Old 08-27-2009, 07:59 AM
tkk tkk is offline
Rep: 48 Posts: 67
Are you running all that stuff also when you are not running the boat? If not, it should be taken into account in your calculations.
Ocean Waves as they reach the Shore brian eiland Open Discussion: All Things Boats & Boating 3 05-27-2009 02:00 AM
5 metre hull - 30 knots - serious off shore passage maker - possible? flowtech Boat Design 13 10-04-2007 10:54 AM
Beyond batteries: Storing power in a sheet of paper kach22i Open Discussion: All Things Boats & Boating 10 08-27-2007 06:51 PM
Fiberglass expert on eastern shore KBbricker Fiberglass and Composite Boat Building 2 08-17-2005 03:30 PM
Power Sports Advanced Battery Charging System 12 Volt wingstech Marketplace 0 04-21-2005 09:48 PM
