Old 12-27-2011, 12:58 AM
K J Thomas K J Thomas is offline
Rep: 10 Posts: 17
Catamaran steering.
Hi
Anyone know if you can use teleflex mechanical rotary steering system to steer two catamaran rudders, without any other link?
Changing a sailing cat to wheel steering. A link rod will be in the way of the dinghy.
I.e. Like the duel steering wheel system in reverse. Two rudders, one wheel.
Kerry
www.altairmarine.co.nz
Old 12-27-2011, 06:41 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
Teleflex makes several two cable system, one helm with two cables. With no tie bar should be no problem, will always be in sync.
http://teleflex.ru/upload/files/cata...on%20Guide.pdf
I like the C-290 Dual system myself, but the Safe-T dual is more than adequate for rudders.
Steve
Old 12-27-2011, 07:05 AM
Rep: 1493 Posts: 7,447
It depends on the load. You have to calculate what the maximum force to be applied will be.
Old 12-27-2011, 07:00 PM
Richard Woods's Avatar
Richard Woods Richard Woods is offline
Woods Designs
Rep: 976 Posts: 691
You can use the Teleflex system on smaller boats. But it doesn't always keep the rudders in line indefinitely. For whatever reason I've known the rudders get out of line. It's not that sensitive either. Remember Teleflex steering is really for twin outboard motors
I think you'll find the cables supplied as standard will both be the same length, which might cause routing problems.
and you have to think about emergency steering
www.sailingcatamarans.com
Old 12-29-2011, 07:29 AM
Rep: 205 Posts: 442
The Teleflex twin Safe T can be used with any length cable including different lengths. They are basically two identical helms stacked on one shaft. The rudders should stay in sync after initial ajdustment.
I believe the Safe T is available with or without teleflex's "no feedback feature," the unit w/o will provide feedback to the helm. Any of the rack and pinion dual cable systems will be "no feedback."
And yes, these are primarily designed for outboard use, actually singles and/or dual o/b over a certain HP, as a choice before hydraulic, but more than adequate for any reasonable rudder load on a typical cat, I would think up to around 40 ft and depending even bigger.
U flex also makes one that will provide feedback:
http://www.marinepartssource.com/new...Steering+Helms
Taming a 150HP o/b with an 8" rudder arm calls for some robust engineering.
Steve
Old 12-29-2011, 08:11 PM
Rep: 10 Posts: 17
Thanks for the replies.
The dual cable helm Solved my problem.
Kerry
Catamaran Steering Systems SPJ yachts Multihulls 0 03-10-2007 06:18 PM
catamaran steering systems SPJ yachts Multihulls 6 03-01-2007 05:13 AM
Catamaran Steering Systems SPJ yachts Multihulls 3 02-27-2007 03:59 AM
Catamaran steering systems SPJ yachts Multihulls 6 02-06-2007 05:40 AM
Catamaran Steering Jim Gard Multihulls 0 04-14-2003 12:19 AM
