Old 10-29-2007, 04:10 PM
justinDesign justinDesign is offline
Rep: 10 Posts: 29
Can Anyone recommend a battery charger?
I am looking for a battery charger for two 12 volt marine batteries that can use both 120 electrical outlet power and solar power to recharge the batteries any suggestions?
Old 10-29-2007, 07:25 PM
lazeyjack
so really you mean input vac, 120? google up smartcharger, does any input vac, and frequency, and can adjust for lead acid or gel(they bulk at different rates)
Old 10-30-2007, 06:26 AM
Rep: 756 Posts: 3,328
Practical Sailor has any of their complete test reports on line for a small fee.
Google them , the info is worth the few bucks.
AVOID "ferroresonant" (older Guest) and other cheap crap, which has killed more batts than they have charged
FF
Old 12-14-2007, 11:22 AM
NEWENGLAND
You need a DC/Dc regulator and AC/DC Rectifier
If your going to use both Solar panels and AC shore power or from a Generator you need a DC/Dc regulator and AC/DC Rectifier
This will do it.
Samyung
Model SP5
Regulated DC/DC and AC/DC rectifier
110/220 VAC Input
24 volt / 15 Amp
http://www.samyungenc.com/eng/index.asp
NAVIS@Maine.rr.com
Old 12-17-2007, 08:55 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
I wouldn't want both in the same case. Buy seperately.
http://www.batterystuff.com/solar-chargers/
Get the $85 one, then buy a
http://www.nimhbattery.com/vdc-elect...harger-12v.htm
OR a good charger with a brain
http://www.batterystuff.com/battery-...rine-chargers/
Don't put all your eggs in one basket
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 12-18-2007, 03:11 AM
cahudson42 cahudson42 is offline
Rep: 10 Posts: 35
If you are charging off-boat or do not need weather-proof, you might look at the BC12B Black & Decker. $36 each at WALMART. I bought a pair for use with 2 105A Everlasts for Trolling motor. The charger is 3-stage with Flotation top-up. Seem to be working great.
They are fan cooled, so I would watch using them in a confined space.
http://www.blackanddecker.com/Produc...roductID=17922
Chris
Old 12-18-2007, 05:55 AM
NEWENGLAND
Big Differance!
After reading the last two relpies I see that your looking for toys and gizmos. Not real Marine Grade Electrical equip.
The Samyung Model SP5 Regulated DC/DC and AC/DC rectifier that I mentioned goes for $595.00 here in the USA.
NAVIS@Maine.rr.com
Old 12-18-2007, 06:31 AM
westlawn5554X's Avatar
westlawn5554X westlawn5554X is offline
STUDENT
Rep: 355 Posts: 1,340
If you can built one use keyproc(dioda) from welding machine to have a nice cool charger... it is not hard. a small version u can install a automatic stop.
Student
Switch with 2 bank charger sdb Electrical Systems 1 03-12-2007 03:20 AM
Recommend a gearbox vkalia Diesel Engines 1 06-29-2006 02:25 PM
Please recommend sailboat plans jmwalker Wooden Boat Building and Restoration 9 08-16-2005 03:38 PM
What do you Recommend S Hondros Education 1 10-25-2004 09:43 AM
