Old 07-25-2011, 06:05 AM
Rogers Rogers is offline
Rep: 10 Posts: 6
Boat steering mechanism
Hey,
I was wondering HOW does the reversed steering mechanism work?
As I know that sailing ships in the 1700's when they turned the wheel right they turned left and vice versa, but today you turn the wheel right and you turn right and vice versa.
How does the latter work?
Thanks
Old 07-25-2011, 07:32 AM
Rep: 1493 Posts: 7,447
It is in the linkage or pulleys. Depending on how you hook them up, they turn one way or the other.
Old 07-25-2011, 10:05 AM
Deering Deering is offline
Rep: 14 Posts: 219
Or sometimes hydraulics. Just reverse the cylinder and voila!
Old 07-26-2011, 03:47 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
It's very simple to reverse the steering with any system, but the purpose eludes me.
I once took the rack and pinion unit apart and accidentally assembled it with the rack below the pinion instead of above it. The effect was hilarious: I hit every object I tried to avoid!
Old 07-26-2011, 03:58 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
I agree
you havnt lived till you have driven a boat with reversed steering..or tried to
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
Old 07-26-2011, 04:24 AM
Capt Mike Capt Mike is offline
Rep: 68 Posts: 26
That would be a new one for me to. I do understand how it could turn out that.
Old 07-26-2011, 04:27 AM
Humans are conditioned so well it is a real mind bender to drive.
Old 07-26-2011, 11:24 AM
pistnbroke's Avatar
I try
Rep: 387 Posts: 1,269
Remembering that the helms man on the titanic was trained in a tiller style ship and threw the wheel the wrong way leaving not enough time to miss the iceberg.
Old 07-26-2011, 02:01 PM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
It's easy to change the action direction. If you push, then to change the direction of the action you pull instead. Have a look at how an outboard push pull steering works. They all pull on the one side, to change the direction you will have to push - or have the cable enter the other way through the motor mounting to change direction.
Regards
Fanie
Water ! Just gimme water !
Old 07-26-2011, 03:46 PM
Rep: 3125 Posts: 9,399
Reversed helm operation isn't difficult to get used to and small boat sailors have no issue at all with it. Flipping a quadrant, rudder stock or head arm or whatever, can accomplish this very easily, though the question of why has been raised.
I was rebuilding a VW transaxle years ago, when I was still willing to crawl under something and turn wrenches. I placed the ring gear on the wrong side of the case, but everything bolted up perfectly, so I reinstalled the transaxle. I quickly learned that I now had 4 gears in reverse and one, rather tall gear in forward. I drove it around for about a month like this, through the local developments to the store, etc. until I yanked the damn thing back out of there and flipped the ring gear to the side it belonged. I became very good and driving the VW bus in reverse at 35 to 40 MPH and now credit this with my expert backing skills.
Old 07-26-2011, 03:55 PM
Fanie's Avatar
Fanie
LOL Par, probably a good thing you stayed with boats eh
Kinky ! They mostly swear at me when I do that...
Regards
Fanie
Old 07-26-2011, 07:51 PM
Nothing changed today, there is still no compulsory training to see if you can drive a ship before you get the wheel/command
Does Anybody Know Where I Can Get A Counter Rotating Prop Mechanism Like A Torpedo? KEMOSOBEE Propulsion 5 09-01-2010 03:18 PM
meshing hydraulic steering with cable steering - how do you do it? Guest1578132542 Boat Design 4 07-14-2010 06:27 AM
Unstable steering on displacement boat melibe Powerboats 11 05-25-2010 03:00 PM
New folding mechanism for old Texas Trimaran Texas-Tri Multihulls 17 01-18-2010 07:36 PM
pivot keel mechanism gja Boat Design 3 01-26-2007 09:32 AM
