  #31
Old 01-19-2009, 03:17 PM
robherc robherc is offline
Designer/Hobbyist
Rep: 102 Posts: 433
oops, 0.21cal fuel lump (just checked the volumes)
  #32
Old 01-19-2009, 03:32 PM
chabrenas's Avatar
chabrenas chabrenas is offline
Mike K-H
Rep: 10 Posts: 100
Wish I could guess things that well when it actually mattered!!!
Maybe you will from now on. All that training has finally paid off...
Mike K-H
http://www.newfreebooters.com
  #33
Old 01-19-2009, 03:45 PM
chabrenas's Avatar
Mike K-H
Rep: 10 Posts: 100
O.25cal vs 0.21cal? Close enough for government work...
Wonder if this is going to up the budget for competitors in the next Vendée Globe?
Mike K-H
  #34
Old 09-08-2009, 12:55 PM
MattZ MattZ is offline
Rep: 21 Posts: 65
You may get some hydrogen chloride (HCl) gas, but very little since this gas is highly soluble in water.
If the sea water gets into the battery you have a different problem that could produce chlorine, and possibly increase the hydrogen output because any sodium metal produced by electrolysis will immediately react with water to produce hydrogen gas.
  #35
Old 09-08-2009, 03:00 PM
chabrenas's Avatar
Mike K-H
Rep: 10 Posts: 100
Thanks, MattZ. Can anyone post the equations for the reactions that take place?
Mike K-H
  #36
Old 09-08-2009, 07:38 PM
Rep: 21 Posts: 65
H+ + Cl- <----> HCl(aq)
Note the double ended arrow, this is a chemical equilibrium. The HCl could then come out of solution. It is a very toxic gas, and on contact with water it will readily dissolve in water to make hydrochloric acid. Due to the high dissociativity of HCl, the yield of HCl should be very small.
Na+ + e- -----> Na
2 Na + 2H20 ------> H2 + 2 OH-
  #37
Old 09-08-2009, 09:38 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
Post number 4 on this thread claims an incorrect average ocean salinity of 2 - 3 %.
The correct figure is 3.9% by weight.
Tom
  #38
Old 09-13-2009, 12:15 PM
Rep: 21 Posts: 65
Tom
3.1% - 3.8%
Varies based on temperature and location. (Typically higher at the equator and poles, lower at the mid latitudes.
Osmosis - Fresh Water vs Salt Water andy_uk Fiberglass and Composite Boat Building 0 05-21-2008 02:40 AM
Burning salt water Bullseye Hybrid 25 11-01-2007 07:43 PM
Problems Yamaha 250 salt water II, stator/C.D.I. bmtsa2003 Propulsion 2 04-12-2006 05:52 PM
please help the new guy!1st time in salt water ss boxfish DIY Marinizing 5 03-14-2006 01:02 PM
Density of Salt water Willallison Boat Design 18 02-20-2004 11:12 AM
