| Batteries in Parallel Hello, I have a 21" boat with an inboard engine. I have 2 12v batteries which I connect in parallel (+ to + and - to -) to start my 12V self starter. I disconnect one battery only when I am not using the boat and it is in the sea thus I leave one battery only connected. Am I damaging the batteries? Thanks |
| Just make sure that they are charged together, it takes about 15 % longer to charge tahn it did to discharge, so be careful. Barreries are usually charged at abpoy 10 % of their amp/hour capacity, so if they were 200 amp/hours, you would be charging at about 20 amps.
__________________ "We do not know, what we do not know!" |
| Thanks for your replies. What I do is that when I arrive on the boat I connect the other battery in parallel and start the engine with both batteries connected. I do not disconnect anything while cruising thus both batteries are being charged. -- Before I leave the boat when the engine is off I disconnect one battery and leave one connected. |
| Why do you leave one connected, is it because of the bilge pumps, if not then disconnect both batteries. The bilge pumps should be wired outside of the main battery switch anyhow.
| Yes it is for bildge pumps as a safety precaution. I do not use switches as if they mulfunctiuon which I found out they sometimes do they have bad consequences. I just unscrew the battery fly nut of the bridge lead. Thanks again |
| OK, no worries, you are doing the right thing.
| Batteries in the bilge? | Squidly-Diddly | Boat Design | 5 | 10-25-2007 08:11 PM |
| ac/dc panels and batteries in the same space? | Westerly23 | Electrical Systems | 1 | 09-21-2007 10:46 PM |
| Moving batteries... | firepiper | Electrical Systems | 1 | 10-21-2006 05:14 AM |
| Running Three Batteries... | JonM81 | Electrical Systems | 3 | 10-09-2006 06:57 PM |
| Custom Batteries ??? | bjl_sailor | Electrical Systems | 4 | 03-05-2005 05:39 PM |
