Old 09-23-2011, 03:48 PM
PAK RAK Man PAK RAK Man is offline
Bad Monterey gas gauge
I have a 1999 19' Monterey and it seems most of the gauges have gone bad, but a real problem is the gas gauge. Anyone else have this issue, and is the fix, the sending unit or gauge itself? Appreciate any advise
Old 09-23-2011, 04:35 PM
Rep: 1493 Posts: 7,447
If you short the pink wire to ground and the gauge moves, it is the sender. A sender and gauge set is not much more expensive than the sender alone. Changing both will make sure there is no problem. This assumes there is power to the gauge now.
Gas gauge barely moves off full when empty John555 OnBoard Electronics & Controls 10 06-02-2011 05:06 PM
Why is my gas gauge stuck on E? (pics) kalel76 Propulsion 4 05-04-2007 01:37 AM
Monterey 248LS Busybee2498 Powerboats 0 09-06-2006 06:55 PM
Float Stuck In Gas Gauge MISSY2U Powerboats 3 03-12-2005 12:22 AM
Monterey 245CR bretherford Powerboats 3 08-20-2004 01:55 AM
