Old 03-04-2009, 05:26 AM
zorton01's Avatar
zorton01 zorton01 is offline
Rep: 10 Posts: 13
Automatic Boat Trim
Hi everybody,
i'm installing the QL Boat Trim system in a 10 meters semiplaning hull. After getting the QL interceptors (Interceptors, control unit, control panel, wires), I saw that QL offers the possiblity of installing something like an automatic trim accesory. The kit comes with a GPS receptor, blackbox and cables to connect to control unit. QL says that system keep in memory the last prefered trim position and corrects position.
I also saw other systems like the followings:
Bennett ATC
ACS+ (Mente-marine.com)
Have anyone had tested an autotrim? Does it Works, or have to be improved?
. That systems seems to be a copy of the gyroscopic units used on proffessional boats but not the same....
Old 03-05-2009, 10:14 AM
BMcF BMcF is offline
Rep: 163 Posts: 383
Those systems use a simple tilt sensor and related processor to slowly vary the tab (or interceptor) position via an integrator to achieve/maintain an average running trim (and list). As such they respond very slowly and do not resemble their much more expensive 'active stabilization' cousins found on larger craft and do not attempt to ( and simply cannot) reduce or dampen transient pitch or roll motions.
They work at what they are intended to do, within the limits of the 'muscle' they produce to modify trim or list within a reasonable range.
Old 03-05-2009, 04:31 PM
Rep: 472 Posts: 1,391
I was hoping that they would do more. Is it a matter of scale or just too slow?
Old 03-05-2009, 04:47 PM
Rep: 163 Posts: 383
Motion damping (as compared to 'automatic' list and trim control) requires a fast-reacting lift device and additional sensores, processing, etc. All that goes along with that is the reason why even small and low-end motion damping systems cost 10s of thousands of dollars..
Old 03-05-2009, 05:11 PM
Do you believe that a large trim plate like K-Plane, if it could be adjusted fast enough would lessen the need for stabilizers in a larger boat?
Free automatic hull fairing … for a boat that won’t need to float! JeromeC Software 2 01-20-2008 10:52 AM
GM 350TH automatic tranny l_boyle Inboards 5 01-05-2007 11:14 AM
Rule automatic bilge pumps. hmattos Electrical Systems 6 12-07-2005 10:43 PM
Trim tabs for a heavy boat stevel Boat Design 0 09-15-2004 05:15 PM
test: automatic thumbnails Jeff Open Discussion: All Things Boats & Boating 6 01-09-2004 12:34 AM
