| Alternitive method of battery charge-second alternator This is a forum from Crew.org.nz in New Zealand. I thought it might be of interest. Greetings to the forum. On this dual alternator discussion I received a well thought out email from Alan concerning second alternators and other charging issues. I am going to do my best to answer, but first let me give you a brief background of where the information I'm going to present comes from. I normally stay away from personal history because it has little to do with charging systems, or the other DIY articles I write, but in this instance my experience is significant to the ideas I am going to present. My wife and I left San Francisco cruising on our 42ft steel ketch in 1987. Since then we have covered well over 150,000 miles on many boats, mostly without marina stays. My wife and I departed San Francisco with 30 dollars and a boat load full of tools. Our idea was to support ourselves while sailing by performing whatever work along the way we could. This was a time just pre GPS and not many yachts were sailing compared to today. Two years later GPS became universally available and yachting has changed forever, or until the satellites fall from orbit. The advent of a real time navigation system meant high priced yacht owners suddenly had confidence to head offshore. I was sailing in Mexico at the time working on worn out cruising yachts and trying to keep beans in the cooking pot. Next thing we know a dozen fully decked out yachts showed up. Each one seemed to have every imaginable electrical device installed. Computers, refrigeration, deep freeze, navigation systems, big battery banks, water makers, high wattage electric lamps and some even had electric trash compactors. On our boat we were still using kerosene running lamps and had none of that high priced gear. It was the start of what has become the modern capable cruising yacht. Since most of these boats were fitted out in Seattle or San Francisco they were built for cold conditions. Soon as the boats hit the tropics the fridge and freezer began pulling double amperage while the single 55 amp engine alternator overheated and failed. It was common for yachts to run the main engine 4-8 hrs a day just trying to keep the beer cold. Being the business man that I am (see “How to make money with boats” at Yachtwork.com or Boatbooks) I formed a team and we began trying to solve the big yacht charging problem. We identified a group of boats that were big enough to have the electrical toys, but did not want to dedicate space to a generator and concentrated on solving the charge issues. Our customer base for our high amperage kits include: -Offshore cruising yachts -Charter yachts such as the Moorings fleet - Beneteau production yachts -Marine electricians wishing for an easy method of driving a large frame alternator. -Yachts with moderate electrical loads that do not wish to dedicate space, effort and spares to a genset. -Large 700+ amp hour battery banks -Yachts that wish to shut down the genset while using the main engine -Batteries such as AGM that can take high charge rates -Split voltage charge systems IE 12/24 volt electrical systems -Yachts with large inverter loads ie. washer/dryer -Yachts that wish for a back up charge system for safety -Yachts that wish to utilize short engine run times to quickly recharge batteries such as cruising boats that only run the engine when lifting anchor. -Yachts with large electrically driven motors such as electric bow thrusters and electric anchor winches We tried every imaginable charging combination over about ten years. We built wind generators, trolling generators, rewinding alternators to get more amperage, petrol deck generators and second alternators. Solving the battery re-charge problems was the topic of radio nets and cruiser parties. Battery regime and charge rates were spoke of of instead of great dive sites. Because our work shop was built into our cruising yacht we sailed along with our customers following the season. I would make two or three installations and then sail with the group to our next destination. In this way I was able to experience firsthand the results of our efforts. Of course our own boat was slowly loading up with all the latest gadgetry also. What we found was this. Alternative power was good, but it only supplemented the main charge from the genset or main engine. The key was more charging amperage. Like they say “There is no substitute for horsepower”. We began rewinding alternators for more output, but the math is bad. We have to remove the 55 amp alternator to install a 100 amp thus gaining only 45 amps. Eventually we set upon installing second alternators. The idea instantly caught on and solved the majority of yacht charging issues in just a few days labor. The constant battle of keeping the yacht batteries charged became a non issue. On every yacht we installed a second alternator the crew stopped talking about amps, watts, charge, friges, and began getting on with cruising. The wives stopped threaten to move off the boat and "camping" on the water became a lifestyle of relative luxury. Building second alternator mounts became a big part of our income. It was great. Cruising our boat around installing duel alternator kits and making people happy at the same time. If you’re interested in doing the same type thing I put out a book “How To Make Money With Boats” that is for sale in NZ (yachtwork.com or Boatbooks) explaining the step by step process of buying a boat cheap and using it as an economic support platform while cruising. It’s really a great system and in use by hundreds of people today. In the 1990's I did a count and found I had over 100 dual alternator designs in the field. I don't know how many designs I now have out, but it's a lot. Not only my designs, but the number or re-designs I regularly get called to fix. It's tricky to make a one off bracket that will last the life of the engine. The failures I get called to typically revolve around systems that vibrated and cracked a bracket, or maybe the pivot point was not right so the belts would not tension correctly. Sometimes the electrical would be done well but the welding was poor, or the other way around. See, it's difficult to find someone that can design and install the electrical and the mechanical side of a dual alternator kit. The thing is I have NEVER yet come across a yacht that has told me "You know the thought of rebuilding my second alternator kit is too much to bear. Let's just remove it". Instead what I hear is "Just fix it. Do what needs to be done, but keep my second alternator installed". I consider this a testament to the fact that a second alternator solves the majority of long term yacht charging problems and it's worth the cost to most owners. A couple more points to mention. Every system I work on I live with. My wife and I have been constantly sailing for over 20 years. When we run out of cruising money we jump to another yacht or boat to work. All the while our comfort level depends on how well we can keep the mechanical systems running at capacity. We live with what we service. Our main engine has a dual alternator system. I have a seven horse power Yanmar diesel that belt drives a 120 amp alternator. We also have two wind generators, a trolling generator and six solar panels. I keep careful tabs on the amount of power we use and how we replenish it. The majority of our charge while cruising comes from the big alternator off a small diesel. Of course while sitting at anchor the solar and wind can keep up, but when on passage the sails shade the solar, and the big electric auto pilot consumes a lot of extra power not to mention navigation lights, radar, night reading lights, and all other electrical demands that are increased when a boat is run24/7. Our typical charging regime is a fast charge from the alternator early in the day while also charging any laptops, fridges, etc. We shut down the engine in time for the sun to take over the charge. We never seem to want for more electricity, but we use a lot of it. So, on to Alan's letter. Because I can't change the text color in the forum text I'm going to give my opinions in capitals. I know many people say it's the same as shouting in text. I'm only trying separate my comments compared to Alan's. One more thing, these are just my quick opinions. Every yacht situation is different, but this is what I see from the designer/installer/consumer point of view… Hi Scott, I have been interested to read your various articles on alternator upgrades (Tradeaboat, your site & your recent crew.org postings). Having been thru one of these upgrades on my own boat it was interesting to compare notes. I do feel there are a few points you should clarify/elaborate in your writings to ensure people are better informed, all of which I am sure you are aware of. My first suggestion to anybody wanting a better understanding of marine electrics is to buy Nigel Calder's Maintenance guide – it seems to have become the definitive reference book I AGREE. NIGEL IS A FANTASTIC INFORMATIVE READ ON JUST ABOUT ANY TOPIC HE WRITES ABOUT. SORRY ABOUT LIMITING THE AMOUNT OF INFORMATION I, BUT TRADEABOAT ONLY HAS SPACE FOR ABOUT 2500 WORDS A MONTH. IT SHOULD BE NOTED 2500 WORDS SHOWS THE AMOUNT OF INFORMATION KIWI'S ARE ABLE TO CONSUME. WHEN I WRITE FOR US MAGAZINES THEY ASK FOR 800-1000 WORDS. Battery Capacity – before worrying about the alternator is there enough battery capacity. It is incredible when you look at the standard specs for the Euro-trash boats NZ is being inundated with how small the standard battery package is – Bavaria 42, 46, 50 and Oceanis 43 all nominating a single 140 ah battery as standard (I know most have battery upgrades but leaves people like yourself to address the charging problem). So bigger is generally needed and I know the selection between wet/gel/agm/hybrid gel types is a never ending debate in itself. My feeling for cost /benefit is to go with T-105 6V type wet cells in the appropriate bank size providing there is adequate external ventilation, maybe with Hydrocaps. THIS IS A GOOD POINT. MOST EURO CRUISING YACHTS ARRIVE WITH NEXT TO NO BATTERY CAPACITY, BUT SEEM TO NEED ABOUT 500-800 AMP HOURS TO CRUISE. THE SYSTEM WE BUILT FOR ROSS BLACKMAN’S BENETEAU 43 HAS AN 800 AMP HOUR BANK AND HE REPORTS NEVER GOING BELOW 700 AMP HOURS. IF HE HAD A 300 AMP HOUR BATTERY BANK THE SYSTEM WOULD NOT WORK NEARLY AS WELL. THIS IS IMPORTANT BECAUSE IN ORDER TO FAST CHARGE WE NEED A LARGER BATTERY BANK. AMAZINGLY MANY U.S. BOATS TOP OUT AT OVER 1600 AMPS. THE TROJAN 105 AND THE 220 RED TOP 6V BATTERIES SOLD IN NZ ARE MY PREFERRED CHOICE. THEY ARE RUGGED DEPENDABLE, FORGIVING, CHEAP, AND SEEM TO LAST SIX TO EIGHT YEARS WITH GOOD CARE. Engine Mounting configuration – having sorted the batteries & determined a second alternator is necessary there is one aspect I feel you should touch on, the matter of allowable sideways loading on the front crankshaft bearing. I went thru this with Power & Marine on my new installation (Yanmar 4JH4 56 hp), in 2005 they were adamant that the max size alternator to hang off the side was 120 amp. In the finish on my installation we went to a jack shaft as I have a refrigeration compressor & Jabsco bilge pump to run as well as the 140 amp alternator. I believe Yanmars have a reputation for being light in the front bearing size, whereas Kubota derivatives can handle a lot higher loading. Have Yanmar since changed their position on the issue of side loads? NOW THIS IS FUNNY TO HEAR BECAUSE I WAS SENIOR TECHNICIAN FOR YANMAR ENGINEERING SERVICES THAT WAS COUPLED TO POWER AND MARINE AND THE BLUE PACIFIC SALES TEAM. I THINK I WAS THE ONE WHO DECIDED ON THE 120 ALLOWABLE AMP DRAW ON YOUR ENGINE. IT WAS A POINT OF DISCUSSION AMONG THE TEAM. I NORMALLY SPEC ON THE LOWER SIZE OF SAFE BECAUSE A COUPLE YEARS LATER I TEND TO HEAR REPORTS SUCH AS YOURS WHERE THE USER INCREASED THE AMPERAGE OF THE ALTERNATOR AND ADDED A COUPLE OTHER DEVICES LIKE THE FRIGE COMPRESSOR. REMEMBER THE MANUFACTURER WAS SAYING NOT SAYING WHAT THE ENGINE WILL HANDLE BUT WHAT THEY ARE WILLING TO WARRANTY. IT’S AN AGREEMENT OF RISK. A SIDE TOPIC TO MENTION IS YOUR ALTERNATOR AND REEFER PUMP BOTH ARE SMOOTH LOADS. THIS SMOOTH LOAD IS A GOOD THING AND GREATLY IMPROVES THE CHANCES OF A TROUBLE FREE LIFE. WATERMAKER PUMPS, HIGH PRESSURE WASH DOWN PUMPS AND HYDRAULICS NEED “HARD” HITS TO PRODUCE THE HIGH PRESSURE THEY RUN AT. THIS IS MUCH MORE OF A SHOCK LOAD ON THE COMPLETE SYSTEM ESPECIALLY THE CRANKSHAFT. ONE WAY AROUND THIS PROBLEM IS ADDING A SMALL NITROGEN CUSHION CARTRIDGE TO THE PUMP INSTALLATION TO SMOOTH THE LOAD. SO HERE ARE THE YANMAR ALLOWABLE HORSE POWER NUMBERS AS I REMEMBER THEM FOR THE JH4 SERIES ENGINE. WE ARE ALLOWED UP TO SEVEN HORSE POWER CONSUMED FROM THE FRONT OF THE CRANK AT MAX RPM'S. THE SLAVE PULLEY SHOULD BE WITHIN 15 DEGREES ABOVE OR BELOW THE CRANK. SINCE THE GRAPH IS RPM RATED IF WE WANT TO KEEP RIGHT IN THE ALLOWABLE HP CURVE WE CAN CALCULATE OUR PULLEY SIZE TO MATCH THE HP THE ALTERNATOR CAN CONSUME. HORSE POWER TO AMPS PRODUCED IS ALSO A POINT OF CONTENTION. MANY TECHS REPORT 25 AMPS AT 12 VOLTS PER HP. I THINK IT'S MORE LIKE 20 AFTER TESTING MANY SYSTEMS IN THE FIELD. SO SEVEN HORSE POWER WOULD BE 140-175 AMPS. IN PRACTICE YOU WOULD NOT BELIEVE THE AMOUNT OF GEAR I SEE BOLTED TO THE FRONT OF YANMAR ENGINES. MOST SEEM TO KEEP WORKING. THE OTHER DAY I SAW A PHOTO OF TWO 200 AMP ALTERNATORS DRIVEN BY AN OLDER YANMAR. I WOULD NEVER TRY TO DESIGN SUCH A WORK HORSE, BUT SEEING IT IN OPERATION I HAVE CONFIDENCE THE LOWER AMPERAGES WE DESIGN WON'T FAIL IN THE LONG TERM. AFTER ALL THAT DISCUSSION WE CAN NOW THINK ABOUT SIDE LOAD. YOU'LL NOTICE THE ALTERNATOR BRACKETS WE PRODUCE PLACE THE SECOND ALTERNATOR ALMOST EXACTLY OPPOSITE OF THE ORIGINAL YANMAR ALTERNATOR. THIS IS NOT BY CHANCE, BUT OUR ATTEMPT TO BALANCE THE LOAD ON THE CRANK. WE ALSO MAKE A HIGH AND LOW VERSION MOUNT. THE LOW VERSION IS THE BEST BALANCE WITH THE ORIGINAL ALTERNATOR. ANOTHER ASPECT TO CONSIDER IS THE SIZE OF THE DRIVE PULLEY. THE LARGER THE DRIVE THE MORE SIDE LOAD. FOR THIS REASON WE ARE USING A 120 MM PULLEY ON OUR JH4 ALTERNATOR KITS. THIS SIZE ALLOWS THE ALTERNATOR TO BE RIGHT IN IT'S POWER CURVE AT ABOUT 1400 ENGINE RPMS AND STILL PRODUCE RESPECTABLE AMPERAGE AT LOWER RPM'S. IN CORRESPONDENCE WITH STEVE DASHEW HE MENTIONED TWO SMALLER ALTERNATORS MOUNTED ON EACH SIDE OF THE CRANK TO BALANCE THE LOAD. I JUST CAN'T GET BEHIND THIS IDEA AS EACH CHARGE SYSTEM HAS SOME MAINTENANCE AND A TRIPLE ALTERNATOR SYSTEM SEEMS LIKE A LOT OF COMPLICATION FOR ABOUT THE SAME CHARGE RATE AS A DUAL SYSTEM. NOW AFTER YEARS WORKING IN THE FIELD I HAVE ONLY ONCE COME ACROSS A PROBLEM FROM SIDE LOAD AND THAT WAS ON A 4JH2 WHERE THE DRIVE PULLEY CRACKED AT THE KEYWAY. THE ENGINE WAS STILL RUNNING FINE, BUT THE PULLEY WAS LEAKING OIL. THIS INSTALLATION WAS DRIVING A WATER MAKER PUMP. The "R" word – surprised that no where have you mentioned the need for an external regulator, preferable of the 3 step type. Maths of adding an alternator – the comment about adding a 130 amp alternator to an original 55 amp installation sending a battery boosting 185 amps into the electrical system is surely a little loose. I expect your installations follow customary practice of directing the charge from the large alternator to the house bank and the original engine alternator to the starting battery, ie the two alternators are complimentary, not additional. I believe the only way to send the sum of current outputs to the house bank would be to replace the engine alternator with an externally regulated alternator and fit one of those fancy Ample Power/Balmar or other regulators with 2 field outputs. Those little 80 amp internally regulated/alternator sensed Hitachi alternators fitted as standard to 4JH Yanmars would struggle to produce more than 50 amps even for an almost dead battery and would be totally confused trying to charge a battery already receiving charge from a high output alternator. EVERY ALTERNATOR INSTALLATION IS BOAT SPECIFIC, BUT MY STANDARD INSTALLATION IS TO DIRECT THE SECOND ALTERNATOR TO THE HOUSE BANK AND THE ORIGINAL ALTERNATOR TO THE ENGINE START AND THEN INSTALL A VSR TO COMBINE THE BATTERY BANKS SOON AS ONE ALTERNATOR HAS SPARE AMPERAGE. IN PRACTICE THE YANMAR ORIGINAL 80 AMP ALTERNATORS PRODUCES THE 80 AMPS THEY CLAIM. I REGULARLY CONFIRM THIS BY USE OF A DC CLAMP AMP. THE STANDARD YANMAR HITACHI ALTERNATORS ARE PARTICULARLY DIFFICULT TO EXTERNALLY REGULATE. THIS IS BECAUSE THE REGULATOR AND BRUSH HOLDER ARE BUILT INTO THE SAME HOUSING. TYPICALLY AN EXTERNAL THREE STEP REGULATOR CAN PASS 10 AMPS THROUGH THE FIELD CIRCUIT. A STANDARD ALTERNATOR USES FOUR AMPS TO POWER THE FIELD SO RUNNING TWO ALTERNATORS OF DIFFERENT AMPERAGES IN PARALLEL FROM ONE FIELD SOURCE IS DONE ALL THE TIME. IN ORDER FOR THIS TO WORK ALL BATTERIES MUST BE IN PARALLEL DURING THE CHARGE CYCLE. I HAVE NOT WRITTEN MUCH ON THE THREE STEP REGULATORS CAUSE THERE IS SO MUCH GOOD INFORMATION THAT I HAVE NOTHING CONSTRUCTIVE TO ADD EXCEPT TO RECOMMEND NEXT STEP AND BALMAR AS MY FIRST CHOICE. FOR THE BROKE CRUISER IT’S WORTH MENTIONING THE THREE STEP REGULATORS WILL COST ABOUT 250 TO 400 DEPENDING ON MODEL. IF YOU JUST CAN'T AFFORD THE COST THE NEXT BEST THING IS THE MOTOROLA REGULATOR FOUND ON THE BACK OF THE LN 130 AMP LOAD HANDLERS. THEY TEND TO HOLD VOLTAGE WELL AND CAN BE REMOTE MOUNTED. THEY DON’T NEED AN IGNITION WIRE AND CAN REMOTE FEED TO AN ALTERNATOR. THEY HAVE A VOLTAGE SELECTIVE SCREW POT FOR FINE ADJUSTMENTS. YOU MENTION THE 50 AMPS A TYPICAL YANMAR 80 AMP ALTERNATOR PRODUCES. IF YOU CHECK AT THE BACK OF THE ALTERNATOR OFTEN YOU WILL FIND THE VOLTAGE IS STEADY AT 14.2 AT 50 AMPS AS IT SHOULD BE, BUT THE TINY STANDARD WIRE ON THE BACK OF THE ALTERNATOR HAS A VOLTAGE DROP AND THUS THE BATTERIES ARE STILL SITTING 13.6 OR SO. TO BE CLEAR YOU ASKED ABOUT FEEDING A LARGE OR COMBINED BATTERY BANK WITH BOTH THE THREE STEP REGULATED HIGH OUTPUT ALTERNATOR AND AT THE SAME TIME THE YANMAR STANDARD 80 AMP ALTERNATOR. THE ANSWER IS THIS IT’S DONE ALL THE TIME. BACK IN THE 80’S DOUBLE REGULATION SEEMED BE A BIT OF A PROBLEM, BUT SINCE THEN I HAVE NEVER HAD A COMPLICATION WITH RUNNING MULTIPLE ALTERNATORS INTO ONE COMBINED BATTERY BANK EVEN IF THE COMBINATION IS THROUGH PARALLEL BATTERY SWITCH. EACH CHARGE SOURCE HAS A SET VOLTAGE AND SIMPLY TURNS OFF WHEN THAT VOLTAGE IS REACHED. THIS MEANS ONE CHARGE SOURCE WILL ALWAYS BE LAST IN TURNING OFF BUT IT HAS NOT SEEMED TO MATTER IN PRACTICE. WHEN CHARGE VOLTS OR AMPERAGES BECOME UNSTABLE IT CAN NORMALLY BE TRACED BACK TO A GROUND LOOP OR GROUND FAULT. THIS IS PART OF THE FLOATING GROUND ISSUE YOU MENTION LATER. YOU MENTION KUBOTA. I SHOULD SAY KUBOTA ENGINES DON'T TEND TO GIVE US MANY MOUNTING BOLT HOLES. THE TIMING COVER AND OTHER BOLTS SEEM VERY SMALL COMPARED TO OTHER SIMILAR ENGINES. EVERY TIME I COME ACROSS A KUBOTA TO BUILD A DUAL ALTERNATOR KIT FOR I HAVE TO SCRATCH MY HEAD TO MAKE A GOOD LONG TERM BRACKET. - Show quoted text - Battery charge acceptance rate – subject to battery type and internal resistance. In short the alternator is unlikely to achieve its theoretical rated current output for a given rpm for any time because of the fast resistance build up. I noted from a recent article of Calder's in Professional Boat builder magazine (talking about the new Odyssey batteries) where he quoted the experience of his Malo 45 (450 amp/24V Lifeline AGM bank with 180 amp alternator) finding that after 15 minutes the charge pulled back to 100 amps (ie about 25% of battery capacity and a lot less than the 40% charge rate commonly touted for AGM's) YES, THE ACCEPTANCE RATE OF BATTERIES IS AN ISSUE. THIS IS ONE OF THE REASONS YACHTS KEEP ADDING LARGER BATTERY BANKS. THE IDEA IS A LARGE AMOUNT OF AMPERAGE CAN BE REPLACED IN THE FIRST HOUR OR SO WITH AN ALTERNATOR THEN THE SOLAR AND WIND TAKES OVER FOR THE LAST BATTERY TOP UP. CHARGE TO 80% DISCHARGE TO 60% AND LET THE SOLAR AND WIND TAKE CARE OF THE REST. THIS HAS BEEN OUR CHARGE REGIME FOR YEARS. WHEN THE BATTERIES REACH 60% WE DIESEL CHARGE AND SHUT DOWN AT 80% AND USE SOLAR. IT'S BEEN A FAIR SOLUTION. YOU MENTION AGM BATTERIES AND I'M PROBABLY GOING TO GET SOME NASTY EMAILS BUT I STAY AWAY FROM THEM. THE FAILURE RATE IN THE FIELD IS VERY HIGH AND HAVING BATTERIES SHIPPED TO SOME FAR OFF LAND IS A CHALLENGE THAT CAN RUIN A CRUISING SEASON. ONE SET OF AGM'S THAT WE REPLACED IN EL SALVADOR COST THE OWNER OVER 5K IN SHIPPING. A GOOD TEST OF YOUR YACHT CHARGE SYSTEM IS TO RUN YOUR BATTERIES DOWN TO 50%. DO THIS BY MEASURING THE AMPS CONSUMED (NOT VOLTAGE). START THE ENGINE AND TURN ON THE FRIDGE AND ALL OTHER DEVICES NORMALLY CHARGED WHEN THE ENGINE IS RUNNING. I.E. LAPTOPS AND CELL PHONE CHARGERS ETC. MEASURE THE VOLTAGE AT THE BATTERIES. TIME HOW LONG IT TAKES TO REACH 14.5 OR WHATEVER YOU HAVE YOUR BULK BATTERIES VOLTAGE SET AT. MANY YACHTS TAKE ONE OR EVEN THREE HOURS TO GET THE BATTERIES UP TO VOLTAGE ON A 400 AMP HOURS BATTERY BANK. A DUAL ALTERNATOR SYSTEM PUSHES THE VOLTAGE RIGHT UP TO 14.2 (OR YOUR CHOSEN VOLTAGE) THUS SAVING THAT HOUR OR THREE IN DAILY CHARGE TIME. FAST CHARGE ELECTRICIANS ALSO CLAIM THAT BY CHARGING AT LOW VOLTAGE THE BATTERIES DO NOT GAS SO THE ACID DOES NOT GET STIRRED THUS SHORTENING BATTERY LIFE. ANOTHER WAY TO LOOK AT THIS IS AN 80 AMP ALTERNATOR MIGHT BE CHARGING AT 50 DUE TO POOR CABLING. THE FIRGE IS PULLING 8 AMPS, AND A LAPTOP MIGHT USE 5 AMPS AND MAYBE ANOTHER 5 AMPS USED IN THE BOAT SOMEWHERE. THAT IS A NET CHARGE AROUND 30 AMPS. BOLT IN A SECOND 145 AMP ALTERNATOR AND WERE SUDDENLY SEEING 175 AMPS AT THE BATTERY. NO WONDER THE VOLTAGE IS PUSHED RIGHT UP TO SPECIFICATIONS. Alternator selection matters to consider: Needs to match battery bank size/charge acceptance rate with reference to its output curve (easy to get curves for Leece Neville, not so easy for Delco in my experience) at fast idle speeds Needs to be externally regulated (I was surprised to find when I purchased my Leece Neville 8LHA that it was not and needed to be converted, Delco CS 144 appears to have options which need to be nominated on ordering) YES, FOR SURE. IF I HAVE ANY DOUBT ABOUT ALTERNATOR SIZE I GO FOR LARGER CASE AND MORE AMPERAGE. THE REGULATOR WILL THROTTLE BACK THE AMPERAGE AS NEEDED. THE DELCO ALTERNATOR LINE HAS THE OUTPUT GRAPH POSTED IN THE USER MANUAL AND I CAN NORMALLY FIND THEM ON LINE WHEN NEEDED, BUT THE IMPORTANT ASPECT YOU MENTION IS THE CHARGE RPM CURVE. AN ADVANTAGE OF LARGE CASE ALTERNATORS IS THEY PRODUCE MORE AMPERAGE AT LOW RPM’S. THE OUTPUT IS ABOUT 90% AT 3000 ALT RPM'S OR SO. GOOD ON YOUR FOR CALLING THE DELCO CS144. THIS HAS ALWAYS BEEN ONE OF MY FAVORITE ALTERNATORS. THIS IS THE ALTERNATOR I TYPICALLY USE TO BUILD ARC WELDERS (SEE TRADEABOAT FEB). MOST ANY DELCO HAS TO BE OPENED TO EXTERNALLY REGULATE IT. I NORMALLY DO THIS BY BREAKING OPEN THE REGULATOR AND USING IT AS A CONNECTION BLOCK. THE REGULATOR TABS THEN BECOME THE FIELD BRUSH TABS LEAVING A CLEAN LOOK. The fan must be correct for the direction of rotation THIS IS A GOOD POINT AND OFTEN OVER LOOKED. NOT ONLY THE FAN BUT REVERSE SPINNING AN ALTERNATOR CAN HAVE OTHER ISSUES. IS THE PULLEY KEYED? NOT ALL NEED IT AS THE DELCO 22SI HAS PROVED, BUT IT MUST BE CONSIDERED. ALSO CHECK IF THE FIELD BRUSHES ARE MEANT TO DRAG BOTH DIRECTIONS. It should be hot rated, ie be able to achieve nameplate output at 90 deg C Its max rpm rating needs to be considered in selecting pulley size -most go to 10,000 rpm but some only reach 8000. This can be a problem getting sufficient output for 3600 rpm engines at low speeds. THIS IS ANOTHER IMPORTANT POINT. I CAN SEE YOU HAVE BEEN STUDYING ALTERNATORS. DELCO'S ARE RATED AT 200F (ABOUT 90C). THAT IS A GOOD HONEST RATING. A TYPICAL 145 AMP ALTERNATOR MAY PUT OUT 185 FOR TEN MINUTES, BUT THEN LEVEL OUT AROUND THE RATED 145. MANY AFTER MARKET ALTERNATOR MANUFACTURES RATE THEIR ALTERNATOR AT 40C AND THIS IS NOT A FAIR RATING FOR THE YACHT USER. FROM EXPERIENCE AND A LASER TEMP GAUGE IT SEEMS AN ALTERNATOR CAN RUN AT ABOUT 120c ALL DAY LONG WITHOUT DAMAGE AND THE DIODE PACK CAN RUN AT OVER 150c AND SURVIVE. Ideally should have isolated casing with positive and negative ouput terminals (not earthing thru engine block) YOUR COMMENT IS REALLY TWO ISSUES. EARTHING THROUGH THE ENGINE AND FLOATING GROUNDS. EARTHING THOUGH THE ENGINE SHOULD NEVER BE DONE. ANYBODY WITH A HIGH OUTPUT ALTERNATOR SHOULD CHECK THEIR SYSTEM FOR A GROUND CABLE DIRECT TO THE BATTERY OR AT LEAST CAPPED RIGHT TO THE NEGATIVE FEED TO THE ENGINE. THE ENGINE HEAD OR BLOCK IS NOT MEANT TO CARRY 240 AMPS. GROUNDING THROUGH THE ENGINE BLOCK IS THE NUMBER ONE REASON I SEE DIODES FAIL. MAIN ENGINE FLOATING GROUND IS THE SECOND ASPECT TO TALK ABOUT. THIS IS A BIT MORE TRICKY AND BOAT SPECIFIC. GENERALLY IF THE ENGINE HAS A FLOATING GROUND THEN THE ALTERNATOR SHOULD ALSO. IF THE ENGINE HAS A PERMANENTE GROUNDING TO BATTERY THE ISSUE IS NOT SO GREAT. THE BIG POINT IS TO TEST THE ALTERNATOR AT FULL CHARGE WITH A CLAMP AMP. YOU SHOULD BE ABLE TO TRACE THE CHARGE ALL THE WAY TO THE BATTERY. THE ISSUES START WHEN AN ALTERNATOR IS PRODUCING 125 AMPS BUT TEN AMPS ARE FINDING PARALLEL PATHS TO THE BATTERY THROUGH MAYBE YOUR SSB OR THE BONDING SYSTEM. WITH A CLAMP AMP YOU WILL SEE RIGHT OFF IF VOLTAGE/CHARGE IS LEAKING THROUGH A PARALLEL PATH POSSIBLY CAUSING SOME CORROSION ALONG THE WAY. DON'T FORGET TO CLAMP THE PROP SHAFT AS THIS IS A COMMON CONDUIT OF ELECTRICAL LEAKS AND THUS CORROSION. Installation matters Ensure there is adequate cooling air for the alternator (rarely addressed) YES, THIS IS IMPORTANT. ALTERNATORS PRODUCE A LOT OF HEAT AND THAT IS THE LIMITING FACTOR TO HOW MUCH AMPERAGE A GIVEN CASE SIZE CAN PRODUCE. WHEN YOU SEE AN ALTERNATOR ZOOPED UP TO 200 AMPS IT SOUNDS IMPRESSIVE, BUT THE CASE CAN ONLY DISSIPATE SO MUCH HEAT SO IT'S KIND OF A LOST VALUE TO HAVE LARGE WINDINGS THAT CAN’T BE COOLED. ANOTHER COMMON TRICK IS TO FEED THE ENGINE ROOM AIR SOURCE RIGHT TO THE BACK OF THE ALTERNATOR. OFTEN WITH JUST A BIT OF EXTRA DUCTING THE ALTERNATOR CAN BE MADE TO RUN SIGNIFICANTLY COOLER. A FRIEND JUST TOLD ME THEY NOW SELL A PLASTIC HOUSING THAT MOUNTS TO THE BACK OF LARGE FRAME ALTERNATORS THAT COUPLES TO A RULE 3" BILGE BLOWER. THIS FORCES A 3" COLUM OF AIR RIGHT INTO THE BACK OF THE ALTERNATOR SIGNIFICANTLY INCREASING THE COOLING EFFECT. I LOOK FORWARD TO TRYING THIS UPGRADE. Suggest a regulator on/off switch, to give the engine a little time to catch its breath on starting before getting whacked with the alternator's load. YES THIS TENDS TO BE AN ISSUE IF THE YACHT DOES NOT HAVE A THREE STEP REGULATOR INSTALLED. THE TYPICAL THREE STEP REGULATOR WAITS 60 SECONDS BEFORE IT BEGINS TO RAMP UP THE FIELD CURRENT. ANOTHER REASON TO HAVE THE ALTERNATOR SHUT OFF SWITCH IS IN THE UNLIKELY EVENT YOU HAPPEN TO NEED ALL YOUR HORSE POWER SENT TO THE PROP. LIKE IF YOU WOKE AND FOUND YOURSELF DRAGGING ANCHOR AND WERE ABOUT TO LOOSE THE BOAT INTO THE SURF. THAT IS JUST THE WRONG TIME TO DIVERT 7 HP TO THE BATTERIES. IF I REMEMBER RIGHT THE JH4 SERIES YANMAR CAN HAVE THE KEY SHUT OFF WHILE RUNNING DISABLING THE GAUGES AND ALTERNATOR BUT LEAVING THE ENGINE RUNNING AS NORMAL. THIS HAS BEEN USED AS AN EMERGENCY ALTERNATOR DISCONCERT TO DISABLE THE 80 AMP (4HP) FACTORY SUPPLIED ALTERNATOR. For dual belt installations ensure the belts are a matched pair YET ANOTHER IMPORTANT POINT. DUAL BELTS NOT ONLY LAST LONGER, BUT THEY ALSO DON'T NEED TO BE RUN AS TIGHT AS A SINGLE BELT THUS REDUCING SIDE LOADS. ANOTHER POINT ABOUT DUAL BELTS IS THEY TEND TO LAST NEAR FOREVER. I HAVE A SET OF DUAL BELTS ON MY ENGINE THAT ARE NEARLY 10 YEARS OLD WHILE THE SINGLE BELTS GET REPLACED EVERY OTHER YEAR. I HEAR A LOT OF TECHS TELL ME MATCHED BELTS ARE NO LONGER AN ISSUE AS LONG AS THE BATCH NUMBER IS THE SAME. IN OTHER WORDS THE FIRST SET OF SMALL PRINTED NUMBERS AND NOT THE FINAL SEQUENTIAL ORDER. IN PRACTICE ONE BELT ALWAYS SEEMS TO BE LOOSER THAN THE OTHER EVEN WHEN I START WITH MATCHED BELTS BUT HAS NEVER BEEN A PROBLEM. ONE MORE REASON TO USE DOUBLE BELTS IS THEY RARELY LEAVE THAT BLACK STICKY RUBBER DUST. ALL OUR MAIL ORDER MOUNTS ARRIVE WITH DOUBLE ‘A’ SECTION PULLEYS. THIS HAS BEEN A GOOD COMBINATION AS BELTS ARE AVAILABLE EVERYWHERE AND NO SPECIAL PARTS SHIPPING HAS TO TAKE PLACE. Ensure the output wires are adequately supported and some form of nylok or lockwashers used on the studs YES, AND YOU WOULD NOT BELIEVE HOW OFTEN A FEED CABLE COMES LOOSE RUINING THE ALTERNATOR DIODES AND MAKING A POSSIBLE FIRE HAZARD. Ensure lock washers and Locktite'd bolts used on new crankshaft pulley Only used tinned copper wire (surprised that ISO standards do not demand this whereas the more stringent ABYC standards do) MANY ELECTRICIANS CLAIM TINNED WIRES DON'T HAVE TO BE OVERSIZED FOR FUTURE CORROSION SO THE INSTALLATION COST IS ROUGHLY THE SAME. A debatable item – whether the output cable should have a fuse in it or not?? FUSING IS INDEED A DEBATABLE ITEM. THE QUESTION IS NOT JUST THE FUSE BUT ALSO WHERE TO FEED THE BATTERIES. YACHTWORK HAS TEAMED UP WITH GREG LEWIS FORMERLY OF TEAM NZ TO BUILD BENETEAU KITS WE SEND TO EUROPE. GREG WIRES OUR SYSTEM TO RUN THE ALTERNATOR CABLES DIRECT TO THE BATTERIES THROUGH A 250 AMP FUSE ON THE POSITIVE SIDE AT THE BATTERIES. OVER THE YEARS THIS HAS BECOME THE LEAST PROBLEMATIC OPTION. NOBODY CAN TURN OFF THE BATTERY SWITCH AND THE FUSE CAN EASILY BE PULLED TO ISOLATE THE ALTERNATOR FOR SERVICE. Miscellaneous I noted your comment about $300 Delco alternators – is this in NZ (seems very cheap) or mail order from USA? MY TRICK TO BUYING ALTERNATORS IS TO USE A MAJOR COMPANY LIKE NATIONAL ELECTRIC (ON THE NET) OR http://www.alternatorparts.com/21-22si_dual_rect.htm AND BUY A NEW 145 AMP DELCO22SI OR 21SI FOR ABOUT 145 USD. A DOUBLE ‘A’ SECTION PULLEY IS 50 AND THE BIDIRECTIONAL FAN IS ANOTHER 50. I SEND IT ALL PARCEL POST FOR JUST OVER 20 BUCKS AND HOPE FOR THE BEST. SO FAR THE MAIL HAS BEEN PRETTY DEPENDABLE. THE ALTERNATOR COMES IN UNDER 400 NZ SO THERE IS NO DUTY TO BE PAID. I HAVE USED THIS LARGE FRAM DELCO FOR YEARS AND IT'S A REAL POWER HOUSE. IF YOU WANT A MEDIUM FRAME ALTERNATOR THE DELCO CS144 YOU MENTION IS WONDERFUL. FOR A SMALL FRAME THE DELCO 12SI HAS BEEN A DEPENDABLE WORK HORSE. I picked up a Craftsman multimeter/tong tester (AC and 400 amp DC) from Sears for US$60. Obviously not as good as a Fluke but has had good reports for occasional use. YEP I THINK I KNOW THE CLAMP AMP YOU MENTION. THESE LITTLE POCKET SEARS CLAMP AMPS ARE A GOOD VALUE. A GOOD ALL AROUND CHEAP METER THAT GIVES DEPENDABLE SERVICE. IF IT'S THE SAME METER I'M THINKING OF THE JAWS ARE SMALL SO IT CAN REACH INTO TIGHT AREAS. IT MEASURES DOWN TO .1 AMPS AND THIS IS GOOD FOR FINDING STRAY CURRENT. ANOTHER OPTION JUST COMING ON THE MARKET IS AN AC/DC CLAMP AMP WITH A BUILT IN LASER TEMP. THIS IS GETTING CLOSE TO THE STAR TRECK TRICORDER WE SAW AS KIDS. I think in spite of all the fancy amp hour meters available, a good analogue ammeter is very useful. I crewed in the Fiji race couple of years ago and the yacht only had an EMON unit, which went on the blink and on top of this had a regulator problem. I had a multimeter so could check voltage but no way of checking current. Carrel and Carrel in Kingsland will make ammeters and shunts up to 200 amps for very reasonable prices (used to supply BEP in the early days). I hope you find these comments of use/interest. This is a subject like so many in boating where there are always various views and opinions. I am happy to be corrected if I have got any of my facts wrong, we can all learn something new every day. Regards Alan ALAN-YOU SEEM VERY UP ON THE CHARGING AND YACHTS IN GENERAL. IF YOU GET BOARD CRUISING THERE IS PLENTY SIDE JOBS ALONG THE WAY FOR GUYS WITH YOUR KNOWLEDGE BASE. I HOPE MY THOUGHTS ARE OF USE. _________________ See Our Earthrace Books and Yanmar second alternator mounts at: yachtwork.com Scott Fratcher Marine Engineer RYA Yachtmaster 200 ton sail/power/ocean/commercial Yachtwork.com Joined: 03 Sep 2005 Posts: 50 Posted: Thu May 22, 2008 1:13 pm Post subject: -------------------------------------------------------------------------------- Boy that's a heap of technical stuff that I must admit I haven't read fully. However in my experience with three vessels fitted with dual alternators over a period of 30years (The first two being commercial fishing boats and last a 12m yacht) it is definitely a very good and simple (low cost and reliable) system. A previous yacht fitted a diode dual battery system was nowhere near as good. We have a 60hp Yanmar 4jh2 with 2 alternators and a frig compressor hanging off the front and touch wood no problems. The motor is about 10years old and has done about 4000 hours. To avoid glazing the bores every time we up anchor we run it for about 10mins at about 3100rpm (max I think is about 3400) and generally cruise at about 2700rpm to ensute the turbo is not coking up - this gives cruising speed in excess of 7 knots and max 8kt+ with 3 blade ss feathering autostream prop (Also very good). _________________ PK Back to top idlerboat registered user Joined: 06 Mar 2005 Posts: 398 Location: Melbourne, Australia Posted: Fri May 30, 2008 12:53 pm Post subject: -------------------------------------------------------------------------------- Thanks for a very informative post PK, I think I will now go back and re read it !!. |
| Latest design from Yachtwork Greetings from New Zealand. Here are some photos of the latest alternator mount from Yachtwork. This is an example of how what a second alternator looks like when mounted as in the discussion of this forum. The 4JH4-TE is driving a forward facing LN 140 amp 24volt (280 amp at 12 volt) large frame alternator on a new build sailing cat. The lower row of photos is the mount for the 4JH4 but designed for boats like the Beneteau where space on the side of the engine is limited. Cheers Scott |
| Alternator charge wire | Brylk1830 | OnBoard Electronics & Controls | 8 | 05-12-2008 01:55 PM |
| breaking Alternator belts | redman2363 | Sterndrives | 11 | 08-06-2007 08:31 PM |
| Solar panel to charge battery | seanform | OnBoard Electronics & Controls | 1 | 07-03-2007 04:26 AM |
| How do you see if alternator is charging? | mr300s | Powerboats | 7 | 07-15-2006 09:54 PM |
| White lead alternitive? | Mikewj | Wooden Boat Building and Restoration | 0 | 02-19-2006 04:28 PM |
