  #31
Old 02-23-2010, 08:52 AM
The copper guy The copper guy is offline
Rep: 10 Posts: 85
Everything you want to run is available in 24v and 36v in Antwerp,
They supply the barges and there boats are floating houses.
It is no big deal to split of 12v for your current requirements,
Better than listening to a gen.
A/K/A .THE CURMUDGEON
  #32
Old 03-25-2010, 07:44 PM
ETEE ETEE is offline
Rep: 10 Posts: 11
Way Late to this Thread........
Thru the purchase of a vessel being scrapped, I've acquired a Seapower 5kw AC belt driven alternator system built by Power Technology,Inc. They are apparently no longer in business and I'm having trouble contacting the company that bought the rights to manufacture(MEPS). I'm looking for a Service Manual w/ wiring diagram. The unit was installed in 2000 and has 50 hours on it. Used to power a computer on a small Geophysical Survey boat, it has true sine wave capability.
Alternator Data Plate:
Input: 140 V. 2.0 Amps
Output: 120 V. 3Ph. 27 Amps 200+ Hz.
Control Unit Data Plate:
Input: 120V. 3Ph. 200+ Hz.
Output: 120V. 1Ph. 42Amps 60Hz.
It has a small Pilot house panel that connects to the Control Unit with a 15pin DIN. I "cracked" the case and the architecture looks like computer stuff I used to repair back in the era of the 286!!! Just about everything electronic its made of is available in a DigiKey Catalog.
If anyone hears of a manual or wiring schematic, please give me a heads up.
  #33
Old 03-25-2010, 10:50 PM
jonr jonr is offline
Rep: 34 Posts: 246
Sounds like a variable frequency alternator (doesn't care much about rpm) plus an inverter.
Perhaps this gentleman still has his:
Captain Rob Cozen
Master Marine Surveyor
P.O. Box 220
Somers Point, NJ 08244
Office: (609) 926-4949 - Cell: (609) 335-1500
  #34
Old 03-06-2011, 02:24 AM
singleprop singleprop is offline
Rep: 10 Posts: 48
useless information
Pls provide the contatct details of this company, else your information is wasted time to read.
Alternator alternative?? steveroo OnBoard Electronics & Controls 13 01-01-2010 11:59 AM
Alternator problem topcatii OnBoard Electronics & Controls 19 07-22-2009 04:05 PM
Alternator question JerryIkemire Gas Engines 8 07-21-2009 05:57 AM
Alternator wiring help 80chriscraftski Powerboats 6 07-09-2009 05:09 PM
How do you see if alternator is charging? mr300s Powerboats 7 07-15-2006 09:54 PM
