#46
Basically there are 2 single pole double throw relays inside, cross wired for this specific application. For electric motors with field windings instead of permanent magnets, reversing polarity doesn't change the direction. If that is the case, only the polarity of the field windings needs to be reversed, but that requires a small modification in the electric motor.
#47
Ive always thought reversible was a luxury any way as your standing right above it,-- just let it out. Personally I like to have my hand on the chain and let the clutch out slowly so I can feel whats going on. There is so many opinions on how to anchor it deserves a thread of its own and that has been done many times. |
#48
| Whitepointer - Not to worry. This thread got beyond my technical abilities a long time ago! Nonetheless, it is interesting and informative to read the creative solutions posted here. However, I really think the Blue Seas ACR is really the most elegant solution to my problem. One $70 component and it's done. |
#49
| The ACR is the way to go. Free falling anchor is not the best way to go but if your lucky, it works. -Tom |
#50
All winches can free fall, its how the experienced do it. With free fall you know when its hit the bottom. You can not feel that from your button. |
#51
| thanks for the replys. i agree frosty, i have been on boats that operate the winch from the dash but they have bowsprits and chain not rope. because mine is a capstan and i use chain and rope i have to stand on the bow anyway so i think i just need to fit a deck switch so i can operate the winch from there. i have never used winchs before so it's good to hear peoples views. |
#52
| Normally you free drop from an electric windlass. Backwinding uses enormous electricity and overheats, wears the motor out fast. as for controllers , naturally you need one at the bow, but you also need a second controller at the steering wheel....this is the only way you will be able to " drive" the anchor out singlehanded. Be sure to install an on off switch at the wheelhouse so you are able to cut the electricilty to the complete windlass control circuit. It with ruin your day is somene accidently press's anchor down while you are steeming at sea. To aid single handed retrieval at the wheel, install an anchor chain counter. Its simply a piece of ferous metal burried into the chain gypsy and proximity sensor that counts gypsy revolution. very accurate . Several on the market. The "Quick anchor chain counter " model is also the wheelhouse mounted up down anchor winch controller. http://www.quickitaly.com/?lng=us&ms...1&cs2=8&stp=ps |
#53
| That's what I thought too, but my new Lofrans winch, replacing the Simpson-Lawrence, doesn't have a freewheel clutch and there is a plastic finger pushing the chain against the sprocket wheel. Without tools, electric operation is the only option. Free fall seems to belong to the past. The Lofrans does have an integrated chain counter sensor but the required display is an accessory offered at a ridiculous $ 390, so I decided I do not need it. In the Adriatic sea there usually is enough visibility to see the anchor touching bottom.
#54
I would be interested to know what Lofrans suggest as an anchoring technique when standing in the cockpit. I have a remote on the bridge for haul, I get the missus to stand and point at the chain direction --I take it from there, may be give it a little tug forward when its about to break free. Work the windlass as little as possible, you seen the amps they can pull and I don't have a fuse, they are as much good as a chocolate tea pot. The mud? well thats another story |
#55
International Rectifier makes some very nice types. MBR10100 >> 10 Ampere 100 Volt , you need 9 - 10 per battery MBR20100 >> 20 Ampere 100 Volt , you need 4 -5 per battery MBR30100 >> 30 Ampere 100 Volt , you need 3 -4 per battery MBR40100 >> 40 Ampere 100 Volt , you need 2 -3 per battery It certainly will make your batteries last longer Bert Last edited by BertKu : 03-29-2011 at 02:18 AM. Reason: Error correction loss volatge |
#56
If what you do works for you, then all the power to you my friend. -Tom Last edited by Submarine Tom : 03-25-2011 at 11:32 AM. |
#57
| It was'nt an argument Tom --just a forum discussion. |
#58
#59
| There is no argument so how could you get into one. Sorry Im not getting into an argument on the definition of an argument. |
#60
| What argument? You've got too much time on your hands Frosty, there's no arguing that! Anchoring has it's ups and downs and it can be a real drag... -Tom |
| 12v/24v | russglass | Open Discussion: All Things Boats & Boating | 2 | 01-09-2009 01:17 AM |
| Looking for a voltage converter | seeds | OnBoard Electronics & Controls | 9 | 07-18-2008 02:56 PM |
| 24V and 12V | wallguy31 | Electrical Systems | 20 | 04-09-2007 08:46 PM |
| Another 12V & 24V question | johnno | Electrical Systems | 8 | 12-03-2005 07:30 PM |
| 12v 24v question | PowerTech | Electrical Systems | 6 | 09-28-2005 08:26 AM |
