Old 06-20-2011, 03:26 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
Bad idea Dave.
Beside the awkward wiring around the engine and the house system's minus being elevated 12V above ground, one of the batteries will be charged to death.
Series charging is quite normal (the 6 cells within one battery), but the state of charge must be equal. If the house battery has been heavily used and the starter battery is almost fully charged, the 28 volts from the alternator will be divided into 12 + 16 V, slowly killing the starter battery.
Nothing beats the solution in post #3.
Old 06-22-2011, 12:50 PM
slow fred slow fred is offline
Rep: 47 Posts: 25
The easiest way is to mount 2 - 12 volt batteries, close to the thruster, go to my earlier post and buy the charger from Minn Kota, You run 2 wires, +and-,about 10 gauge, from your engine battery to the charger. The alternator on your engine will charge the 2 batteries. I have used this setup for 2 years with no problems.
Old 09-05-2011, 07:59 AM
gdufus gdufus is offline
Rep: 25 Posts: 14
I know it is an old post but maybe for archive purposes, I charged my batterypack (24v, bowthruster) with two small (1' x 1') solar panels, switched to 24v. the panels were spec'd at 10w, but as the bowthruster is not needed on a daily basis usually, they always kept my batteries fully charged
12 Volt DC Vs. AC Genset ChrisN67 OnBoard Electronics & Controls 7 02-22-2009 03:49 PM
12 Volt Microwave Ovens Willallison OnBoard Electronics & Controls 9 12-24-2008 05:25 AM
Mini 12 volt ATX PSUs Tim B OnBoard Electronics & Controls 22 10-08-2007 07:22 AM
cheap 12 volts!!!! terabika Electrical Systems 48 10-13-2006 01:33 AM
12 volt dillemma gasdok007 Electrical Systems 5 04-25-2006 10:25 AM
