Old 04-16-2010, 10:29 PM
BTPost's Avatar
BTPost BTPost is offline
Rep: 85 Posts: 47
There are a lot of DC/DC Converters of various Power Ratings that have a Wide range of DC input Voltages, that deliver Regulated 12 Vdc outputs. I use some 15 watt Blocks that have a 8-18 VDC Input, and deliver 12 Vdc Regulated Output at 1200 ma output. These come in Isolated and un-Isolated versions. These would happily run a small 12 Vdc LCD Panel and they are in the 90% efficient range, so they are not to hard on the existing system.
Bruce in alaska
Old 09-21-2010, 02:36 AM
jfkal jfkal is offline
Rep: 10 Posts: 9
I have been running loads of 12V specified equipment including cameras, PC's monitors straight of the boats 12V (12-14.4V :-) ) supply without any issues whatsoever. Used to make my own 12 V regulators in the past but binned them all. Works just fine for me without them.
Old 09-21-2010, 11:24 AM
jonr jonr is offline
Rep: 34 Posts: 246
I'd at least use an inductor/capacitor or inductor/battery filter + zener diode or varistor (as TerryKing mentioned). I'd use a boost/buck voltage regulator if I suspected that the equipment needed exactly 12V.
Depending on what other equipment there is, 12V systems can get some big voltage spikes.
Old 09-21-2010, 11:58 AM
CDK's Avatar
CDK CDK is offline
retired engineer
Rep: 1425 Posts: 2,252
A dusty old thread where the original poster never responded, but it somehow it stays alive!
I have a TV set made by a Chinese company called "nFren", part of the furniture of my RV. Works perfectly with a running engine (14 V) and also with a fully charged battery, but as soon as there is the slightest dip, caused by opening the fridge or switching something on, the fluorescent tube the provides the LCD back-lighting switches off. Switching the TV off and on again is the only way to get the picture back.
So using electronics from 'raw' 12 V isn't always that easy.
battery monitor issues binglax09 OnBoard Electronics & Controls 0 06-25-2008 09:45 PM
Using 12v System to Directly Power Computers and other DC Eq. JPC OnBoard Electronics & Controls 40 12-31-2007 06:01 PM
Monitor wind gear idlerboat Sailboats 1 02-20-2007 11:26 PM
bilge Pump monitor odyssey11 Marketplace 0 10-24-2005 06:05 AM
uss monitor Sean Herron Boat Design 3 01-16-2005 12:21 AM
