  #31
Old 10-05-2013, 03:19 PM
Manie B's Avatar
Manie B Manie B is offline
Rep: 1818 Posts: 2,039
good luck boys and fair winds
it wont be easy
  #32
Old 10-05-2013, 03:21 PM
El_Guero El_Guero is offline
Previous Member
Originally Posted by DCockey View Post
Jeff MacInnis and Mike Beedell sailed through Northwest Passage on a Hobie 18 during the summers of 186 - 1988. There trip is thought to be the first through the Northwest Passage without using an engine.
http://www.excellenceevents.com/exce...olar_pass.html
And I thought global warming was 'recent.'
  #33
Old 10-05-2013, 03:37 PM
Previous Member
it wont be easy
I wish them fair winds and following seas.
But, it seems they want this for the record books, am I right?
Circumnavigations are supposed to round the southern hemisphere. Going through the panama canal requires powered (non wind) transportation as well.
So, I am a little confused on this. It sounds more like a crossing of the 3 seas rather than a circumnavigation?
Although I admit, a blown up kayak would be a challenge in the southern seas.
  #34
Old 10-12-2013, 07:26 PM
Corley's Avatar
Corley Corley is offline
epoxy coated
Rep: 826 Posts: 3,458
They are off on the second leg of their journey from La Corogne to Santa Cruz in the Canary Islands the tracker is here:
http://defisma.com/suivi-en-temps-reel-du-defi-sma/
Multihull Yacht Club of Victoria
https://www.facebook.com/MultihullYachtClubOfVictoria
blog/projects http://trimaranproject.blogspot.com.au/
  #35
Old 10-13-2013, 02:38 AM
oldsailor7's Avatar
oldsailor7 oldsailor7 is offline
Rep: 436 Posts: 2,094
Quote:-
It's disappointing that Nina for example didn't carry a proper automatically deploying epirb much of the waste of money in that case is tied to the fact the SAR teams could not determine an accurate area in which to search. New Zealand are prepared to take the economic benefit from having yachts stop in they cant divorce themselves from the responsibilities that are part of that including SAR when required.---- Quote.
It can be done.
During the 1969 New York/Bermuda multihull race, all the boats carried epirbs, provided on a loan basis by the company I worked for at the time, Garret Airesearch. LLC.
  #36
Old 10-21-2013, 04:46 PM
Corley's Avatar
epoxy coated
Yvan and Vincent are making progress on their journey from La Corogne to Santa Cruz in the Canary Islands. They were beaten up initially by the weather but are now sailing in lighter trade wind conditions.
http://defisma.com/calme-apres-tempete/
  #37
Old 10-21-2013, 07:47 PM
SamSam's Avatar
SamSam SamSam is offline
Rep: 971 Posts: 3,429
How much time is this expected to take?
How many divisions has the Pope? J. Stalin
  #38
Old 10-21-2013, 07:55 PM
Corley's Avatar
epoxy coated
A long time, it could take a year or more for the circumnavigation the boat is not particularly fast.
  #39
Old 10-21-2013, 08:43 PM
sharpii2 sharpii2 is offline
Rep: 611 Posts: 1,730
Not surprising due to it's probable weight.
Multis are only fast when their weight is kept down.
Hard to do that with a lot of cruising gear on a boat of limited Length.
A Mono of the same length and weight would probably be nearly as fast and, even without ballast, probably safer and more comfortable.
The stores could be stowed in such a way as to act as self righting ballast, or go a long ways toward that. But a mono of that Length completing such a voyage would be hardly worth any print.
Of course a multi, cat or tri, with fatter hulls could keep the wing deck at a more reasonable height above the sea and even allow for higher speeds, as there would be less whetted area exposed to the sea (the wing deck)
But if that were done, the sailors would certainly inhabit the hull(s), spoiling the record attempt.
I think this record stuff is getting a bit silly.
Are we just glorifying people's ability to endure needless suffering?
100 strokes per once of fresh water? Man that's a lot of work.
I never learned a thing from an argument I won.
  #40
Old 10-21-2013, 09:09 PM
buzzman buzzman is offline
Rep: 99 Posts: 483
A circumnavigation ...is a circumnavigation.......whether you go "via Panama" or around the "three Capes" in the high latitudes.
Of course, if their attempt at the middle passage is successful, how long will it before before someone even crazier decides to attempt the three Capes route?
Personally, I'd rather have a storm cover over the wing pod, at least, so you could get dry and sleep, as both of these seem to have been the MAJOR problems for all other trips by open cat.
Both Pradel and Laurent suffered severe sunburn and sea sores because they were unable to get dry at all, Daniel even required skin grafts, and both stated that sleep was well nigh impossible until they were so exhausted they simply fell asleep where they sat - but that type of sleep, especially when interrupted, does not properly rest the body.
But good luck to the "mad Frenchies" anyway - it's certainly a major effort, although it looks like they are coast hugging down the African coast, rather than taking the straight run offshore to the Azores.
Typically, the website has no translation.....bloody Frogs..!!
  #41
Old 10-21-2013, 10:15 PM
SamSam's Avatar
Has anyone ever done a North-South circumnavigation?
  #42
Old 10-21-2013, 10:28 PM
Rep: 99 Posts: 483
Bit problematic, with the continent of Antarctica in the way..!!
Closest so far is probably Matt Rutherfords circumnavigation of the Americas via North West Passage and Cape Horn
http://www.solotheamericas.org/
  #43
Old 10-24-2013, 11:32 AM
SamSam's Avatar
It looks to be more direct than all the dodging around the Americas and Africa in an E/W track, but that would more or less be the course, down the Pacific and up the Atlantic or vice versa.
  #44
Old 10-26-2013, 05:46 AM
Previous Member
That is a nice looking beach cat ....
  #45
Old 11-01-2013, 11:37 AM
Sleepingsadhu Sleepingsadhu is offline
Rep: 10 Posts: 3
Best of luck to these folks, any live tracking?
beach cat Natsu Multihulls 17 04-14-2010
05:32 PM
3m Beach Cat Capn Mud Multihulls 0 07-20-2009
10:51 PM
Folding Beach Cat jtremolo Multihulls 8 05-31-2008
10:29 PM
Beach cat building sailinaggie Boatbuilding 5 03-08-2007
08:53 AM
Wooden beach cat mrthethird Wooden Boat Building and Restoration 11 09-20-2005
07:56 AM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
