  #241
Old 03-21-2015, 10:45 PM
Corley's Avatar
Corley Corley is offline
epoxy coated
Rep: 826 Posts: 3,473
Yvan is due to depart at some stage today from Sri Lanka towards Djibouti. I've been keeping an eye on the tracker but no movement as yet.
http://ledefidyvanbourgnon.com/suivi-en-temps-reel/
Multihull Yacht Club of Victoria
https://www.facebook.com/MultihullYachtClubOfVictoria
blog/projects http://trimaranproject.blogspot.com.au/
  #242
Old 03-23-2015, 02:37 AM
Corley's Avatar
epoxy coated
Yvan has departed and the tracker is working. I couldn't log on for some reason till now.
Yvan Bougnon's circumnavigation in a beach cat project-yvans-current-position-2015.jpg
  #243
Old 03-23-2015, 03:23 AM
teamvmg teamvmg is offline
Rep: 22 Posts: 124
It's pirate central where he's heading. Hope the French Navy know he's coming
  #244
Old 04-01-2015, 06:30 PM
Corley's Avatar
epoxy coated
For those who are following Yvan's adventure the log updates are now available in English as well.
http://ledefidyvanbourgnon.com/les-actualites/
  #245
Old 04-01-2015, 08:31 PM
buzzman buzzman is offline
Rep: 99 Posts: 485
Sorry, not seeing it...only Francais.... ????
  #246
Old 04-01-2015, 08:47 PM
Corley's Avatar
epoxy coated
The title page is in Francais but if you click on the entry hyperlink lire la suite (the equivalent of read more here) it will show the full article and if you scroll down past the French the English translation is below. Not all of the entries have been translated as yet.
  #247
Old 04-01-2015, 09:57 PM
Rep: 99 Posts: 485
LOL...looks a bit 'google translate' but is enough to follow....
  #248
Old 05-22-2015, 04:23 PM
Corley's Avatar
epoxy coated
Yvan is in the Med now after successfully navigating the red sea and approach from Sri Lanka. I've been following on FB lately as the news trickles out through several different sites and it's tedious to follow them all.
https://www.facebook.com/yvan.bourgnon
  #249
Old 05-22-2015, 04:54 PM
pogo's Avatar
pogo pogo is offline
ingenious dilletante
Rep: 73 Posts: 332
"Parlez-vous pommes-frites ?"
"Oui oui mon general, il pleut, il pleut !"
I'm regretting all mono-languagers
pogo
Immer handflach Wasser unter`m Schwertschlitz !
  #250
Old 06-18-2015, 05:54 PM
Corley's Avatar
epoxy coated
The latest update from Yvan Bourgnon he believes that he will arrive at Ouistreham Riva-Bella on the morning of 23rd of June completing his round the world voyage. I'm not sure about how much suffering most adventurers suffer on their round the world attempts but Yvan's epic must be right up there in the pain and discomfort stakes.
https://www.facebook.com/yvan.bourgnon?fref=nf
This is a computer translate so expect the usual funnies but on reading not too bad .
It's official, yvan arrives on 23 June in the morning, Ouistreham Riva-Bella. It should arrive in the morning and wait a little in the channel because the tide schedules are that it will not be able to return his "Louloutte" in the lock before 12 pm. This will be the end of a journey started in October 2013 the sables d ' Olonne. In 220 days of Sea Yvan will have travelled 55 000 km around the globe, traversant three oceans and 13 seas. It will be carried out a couple of steps, during which the small size of its catamaran to often fueled the curiosity, which allowed him to make pretty unknown meetings from spontaneously offer their help in this sailor like no other, on a boat Not like the others... Get out as much as possible of the infrastructure all organized for boaters of passage, and put the most possible implemented the motto of his trip: A catamaran, a beach, a meeting...
But "Do Not Ferlons The Mainsail before the chain is tense" (Maritime Version of the skin of the bear not killed) Because Yvan is still in the sea! As long as the line is not taken, any little happen. It has easily crossed this morning the mer d ' Iroise Case: The Breast Raz First of all a little against the current, and then the dreaded channel of the oven, passing between the archipelagos of Mullein And Ushant on the one hand and the Pointe Du Finistère. The Mer D ' Iroise Case Separates The Atlantic Ocean of the English channel, which she draws the characteristics: The waters vives. The English channel to its entry does not measure "that" 100 miles (180 km) wide, on the scale of the planet, it is a small stream... Whose width will gradually be reduced to measure more than 60 miles between cherbourg and the Isle of Wight.
With the very low average depth (less than 100 m in the middle) and the particular form of the cotentin, all of this makes the very singular place for sailors: At some points, there has been the most strong currents of Europe with more than 12 Knots Registered En Pointe. There are also the third place of the tides the highest in the world... Navigation conditions very specific who play a lot about the state of the sea, but also on the roads of navigation. This is the place where all boats, from the smallest to the largest, "walk in crab" (when the height of the current is across the road)
And to make matters worse, it is also one of the places with the most world maritime trade...
On the side of Yvan, the technical problems accumulate. No pilot works, ais not more and one of its rudders still has broken its axis forcing him to change it at sea... It was the last of its stock... It should be now that this takes up at the end!
  #251
Old 06-24-2015, 09:46 PM
Corley's Avatar
epoxy coated
Yvan has completed his journey:
From Scan Voile
http://www.scanvoile.com/2015/06/def...amaran-de.html
Challenge / around the world in sport catamaran curly for Yvan Bourgnon, arrived at Ouistreham! (Images)
After a course of 55 000 km around the planet on his small sport catamaran, the adventure of Yvan Bourgnon ended yesterday after 20 months of navigation. Party in October 2013 of Sables D'olonne, after beaching, two capsizing, and thousands of hours spent at the tillerr, the sailor crossed the line yesterday in Ouistreham, marking the end of his journey on June 23, 2015.
Challenge Atlantis Television, the first round of the world uninhabitable sailing
Yvan Bourgnon completed its World Tour! He arrived yesterday at 1 pm at the port of Ouistreham Riva Bella.
Back on the adventure
October 5, 2013, departure from les Sables D'olonne. November 2013, first storm with more than 60 knots of wind and first capsize.
February 2014, the sailor is the Panama canal with the ship dismantled, put on the deck of a sailboat.
August 2014, after 19 days at sea in full monsoon, Yvan Bourgnon ran aground at night on the coast of Sri Lanka. A part of the boat is destroyed.
March 2015, after repairing his boat on the place of his grounding, he resumed his challenge.
Around the world of Yvan Bourgnon in figures
55,000 km travelled either 220 days at sea
20 stages, 3 oceans and 13 crossed seas
10.5 km/h, speed average over the whole route
7 storms to more than 90 km/h
2 capsizing,
2 falls to the sea
12 hours of hand steering per day (on average)
  #252
Old 06-28-2015, 03:42 PM
W17 designer W17 designer is offline
Rep: 21 Posts: 77
Yvan defies the sceptics
Incredible! .. he's finally home.
http://www.euronews.com/2015/06/23/s...rld-challenge/
What a great story and adventure we've been privileged to follow and seem part of. Surprising and sad that it was virtually ignored by the English press though ... their loss!
[I initially attempted to write this up on 'What's New' on my website, but other priorities did not allow me to keep up so only the initial 1/3 is there]
But thanks to those, particularly to Corley, who kept this thread going all the time, when it's so easy to be distracted by other interests.
Perhaps one of these days, we'll see more of the story written up, to re-savor the excitement and adventure.
Meanwhile, back to sailing my W17. One owner just finished a 6 week cruise in the China Sea .. but as adventurous as that was, it's just 'a grain from the beach', compared to this epic voyage.
Thanks again Yvan for pushing the limits and showing us what can be done, with proper preparation, personal strength and perseverance. We all salute you!
mike
www.smalltridesign.com
  #253
Old 02-02-2017, 02:01 PM
Rep: 21 Posts: 77
Hi guys
While the story might now be considered 'old news', if anyone wants to look it over in English text, you're invited to my website at 'What's New'. I've recently added a Jan 2017 PostScript to wrap up the adventure.
http://www.smalltridesign.com/whats-new/defi-SMA.html
cheers
mike
  #254
Old 02-02-2017, 02:05 PM
Corley's Avatar
epoxy coated
Thanks Mike.
  #255
Old 03-01-2017, 04:30 PM
Corley's Avatar
epoxy coated
Yvan's next solo adventure with his little catamaran looks to have a timeline now. A recent wide ranging interview in L'illustre examines his adventure sailing around the world on his catamaran and his upcoming attempt over Summer to sail through the North West passage.
http://www.illustre.ch/magazine/yvan...tous-les-jours
beach cat Natsu Multihulls 17 04-14-2010
05:32 PM
3m Beach Cat Capn Mud Multihulls 0 07-20-2009
10:51 PM
Folding Beach Cat jtremolo Multihulls 8 05-31-2008
10:29 PM
Beach cat building sailinaggie Boatbuilding 5 03-08-2007
08:53 AM
Wooden beach cat mrthethird Wooden Boat Building and Restoration 11 09-20-2005
07:56 AM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
