Old 10-24-2010, 03:31 AM
easywake easywake is offline
Rep: 10 Posts: 6
Would this make a good domestic cat?
I came across this concept drawing the other day and it seems to be a lot of what I am looking for in a live aboard boat. The designer states that there are no plans for this boat. A 3d model can be viewed at www.triloboats.com/modeltours.html
I would like to keep the beam to 14ft max so as to be able to road transport the boat complete. It seems like a practical design that would allow a lot of cabin space and a good amount of space for tankage and utilities in the hulls. Probably plywood/epoxy construction. I would also be curious as to if anyone has seen a similar boat or plans before.
This is to be a long term project after one or two smaller boats for building experience. Any feedback will be greatly appreciated. Russ
Old 10-24-2010, 07:10 AM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
A well planned out cat has a lots of room that can be used as accomidation !. What sort of power would you be thinking about to get from point A to point b etc . Tankage for fuel and water . Could use a single motor and use hydralic drives for the two props along with the capstain etc and the same motor for generator to charge a bank of deep cycle batteries for lighting etc . Gas for cooking and refridg
Making beautiful boats is a passion never a chore !
Old 10-24-2010, 11:30 AM
Rep: 10 Posts: 6
Had originally been thinking of twin outboards, but the hydraulic drive sounds fascinating. I will look into that. Probably some solar panels. LP for stove and fridge seems most practical.
My biggest concern is narrowing the beam to 14 ft to keep it highway movable with reasonable resources. I have friends in the manufactured home business to help with moving and 14W is the norm with them. I like the 40L x 20W configuration, but I would need to have the hulls separate and the bridge deck/cabin in sections small enough to transport. Not sure if my skills would be up to that. This is going to be a home build for our retirement cruising. Looking mostly for an ICW cruiser with the capability for a fair weather passage to the Bahamas. Building for further island hopping will probably be beyond my resources (but very desirable)
I have zero design experience with boats of this nature. I am looking for suggestions to wring out a rough plan before I hire the plans out.
Any discussion will be greatly appreciated! Russ
Old 10-24-2010, 12:06 PM
apex1
Looking mostly for an ICW cruiser with the capability for a fair weather passage to the Bahamas. Russ
Bahamas?
Not with such boat. And the desire to stay narrow for road transport, even restricts your areas on inland waterways!
Either, or!
Sorry for that.
Richard
Old 10-24-2010, 02:06 PM
Richard Woods's Avatar
Richard Woods Richard Woods is offline
Woods Designs
Rep: 976 Posts: 691
I have a proposal for a boat like that, see my New Designs page of my website, righthand side.
And it is designed to go to the Bahamas
www.sailingcatamarans.com
Old 10-24-2010, 02:37 PM
Rep: 10 Posts: 6
Originally Posted by apex1 View Post
Bahamas?
Either, or!
Sorry for that.
Richard
Richard, does that come from the narrow beam idea, or do you feel it would still not be suitable in the 40 x 20 configuration as shown. If the beam needs to be wide with this type of boat, I would be willing to try to work around the transport thing. I'm about 55 miles from the Phila. area to get it into the water. I'm sure there must be a workable solution. Are all big cats built at the water? (gently please, I'm new to all this )
Old 10-24-2010, 02:40 PM
Rep: 10 Posts: 6
R. Wood, Thanks, that's an attractive boat. I will keep you in mind. Russ
Old 10-24-2010, 03:35 PM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
http://www.strandednaked.com/
This Houseboat goes from West Palm to Abaco in the Bahamas every year. In the summer you pick your day and with a 5 knt boat its a 10 hr crossing. In the summer the conditions are very easy to forecast with typically only the occasional thunderstorm to worry about. When I was much younger I sailed my Hobie 16 along with 2 other Hobies from Miami to Bimini in the Bahamas.
I personally think its a mistake to try and make a catamaran trailerable, too much compromise. If you want trailerable stick to a monohull.
A couple of 4 stroke outboards will serve a catamaran like that well for a reasonable cost and reasonable economy underway. Better would be inboard diesel but big initial investment with long wait for return.
Hydraulic drives are proven, but not necessarily off the shelf drive units and I believe in the end more expensive than 2 diesels (considering that the hydraulic drive was to be diesel) There is also a fair amount of energy lost in transmission with a hydraulic drive and no redundancy.
Steve
Old 10-25-2010, 07:54 AM
apex1
My concern was beam, yes.
And no matter what others may have done (the most silly idea is not always the best proven), crossing open water in a craft designed for sheltered waters is not safe. The given example might never have met a fast running tug nearby? If that happens they probably know better, all weather forecasts ignored.
Of course not all wide craft are built at the coastline. I produce yachts up to 9m width, with 400tonnes displ. 20km from shore.
Just pick your design appropriate for the task, not for the road transport, that was what I meant.
People tend to imagine more requirements than they have in reality, the ocean crossing trailer sailer is one mad example.
Regards
Richard
How to make our boat performance good? Hutaru Boat Design 8 08-03-2010 02:04 PM
2 kayaks to make 1 cat ? fabrice Boat Design 14 03-26-2009 04:46 AM
Would this make a good coastal cruiser? boat fan Boat Design 22 09-20-2008 11:50 PM
OK DUmb Question - How do I make a cat in Freeship? alexlebrit Software 4 06-04-2007 12:57 PM
two trailer sailers to make a cat markcampbell Multihulls 20 04-22-2006 09:43 PM
