| Stratosphere used the same mould for top and bottom, also bow and stern were the same too, cleverly used, then the two ends of the popped laminated hull sections were laminated together, top and bottom; also the in and out side pods utilized the same method but with differing packings to create the shorter lengths and half rounded ends. I remember looking at just a few quite small moulds lying around at Mahurangi, yet this great big boat had come from them. So that is why Stratosphere's bows set up a great fountain of spray because the bow was also the same shape as the stern. David was slightly sensitive to gauche and impolite suggestions from some observers about this continuous bath ... so on his own Sundreamer, he packed the mould with an insert to maker a finer bow shape when laminating the front sections As K J Thomas has already mentioned, the hulls were angled inwards purely to reduce the beam lengths, also weight. This gave the impression of the hulls being asymmetrical ... but they weren't/aren't. David Barker's earlier 40 foot Sundancer also had angled inward, but fine, symmetric hulls; he had studied CSK cats (with asymmetric hulls) when he was in Hawaii and thought he could design a better hydrodynamic hull but with the same CSK look, which he admired. Newick's Atlantic proa Cheers had a high, leeward blister added later after a lean over during trials; also the Brown proas have hull like blisters for halting tipovers if caught aback, on the upwind side too. |
| Illustrations to the above and perhaps the one in Jipsters mind. |
![]() HASYB close, or is it http://www.wingo.com/proa/brown/jzerro.html wiki say's Russ Brown started those sidepods in the mid seventy's jzerro did 20knts but the boat was a pile of **** Brown say's Jim Antrim did some stability pics on a side pod proa |
| Remember boats aren't just or sailing/motoring. Sometimes you have to come alongside. The fenders needed for a catamaran with side pods, or the proa above, have to be very big to protect the boat from most pontoons/docks (Think of what's needed in the boat photoed above). And of course you cannot overhang the dock itself, so even coming alongside will be tricky So I agree, its better to increase the hull separation Richard Woods of Woods Designs www.sailingcatamarans.com |
| Bernd Kohler also did an extension on his personal boat he lives/lived on. http://www.ikarus342000.com/PELICANpage.htm |
| It seems the way to dock the proas would be with the ama to the dock. At least no one could figure out how to raft on to you! |
| When brand new Sundreamer won the reintroduced Auckland/Tauranga, we tied up to the usual type floating dock there (with zero problems because the port pod overhung the pontoon) ... but visitors, fascinated by this unusual marine spaceship, would walk along banging the pod with hands, keys etc - sounded like continual drumming from inside. I think David wrote a polite note, didn't stop it though. So that was a minor and not envisaged aspect. Actually tying up to a conventional wharf was no problem; you just hung the buffers strategically over the pod. |
| Haysb, that's a very young Halvard Mabire on the beam of Tahiti Douche - Atlantic proa designed by Daniel Charles. |
| I have heard to build a 60' cat with symmetrical bottom and top can save cost about Euro 50000 on mold, it's really clever and good option for DIY project. When I work with my friend to developing it in 3d , we found out it 's hard to change the deck with a flat walkway and expand the steps on stern ...we still need to experiment more idea to improve it. if anyone have idea or photos that would be helps. Thanks |
#25
#26
#27
| **** Quote:
came acros a recent interview copie from a newspaper or so wherein Russ Brown besides good memory's and results mentioned **** as well one of my favorite proa designs too, but parking may be something else when those roofknockers tell there are green man with antennas inside ![]() |
#28
#29
| No, that was Ena Hutchinson's article with photographs by editor David Pardon. I took the small interior construction shot; the first couple of pages were left out of the pdf. - but I did this small piece in my monthly column. |
#30
| Docking could be tricky as mentioned. I believe docks come in all shapes and sizes and height's above water, so excellent chance any overhang would be the worst possible mis-match, Murphy's Law and all that. Half the time your overhang will be slamming hard on the dock with every little wavelet that passes by. I once thought it might be nice to have side tramps, since a cat doesn't heel much. Maybe if you had an overhang you could use poles to dock and put tramps on the poles, but then you are taking up WAY to much marina space. Maybe fairly narrow side tramps on poles that could be raised or lowered or hinged to connect to docks and also provide nice wide ramp. |
| New to cats | davekf | Multihulls | 24 | 04-01-2009 11:36 AM |
| New Trend For A-Cats? | TTS | Multihulls | 0 | 06-28-2008 07:25 PM |
| cats on foils | northerncat | Powerboats | 2 | 07-31-2007 07:08 PM |
| T Foils on Cats | grob | Multihulls | 7 | 09-25-2006 03:43 PM |
| wharrum cats | kenneth | Boat Design | 1 | 03-05-2006 07:54 AM |
