Old 10-13-2010, 10:55 AM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,602
Whites Dragons-mini hydroptere-esq
Whites dragons: designed and being developed at University of Gonova(Genoa)....Different then Hydroptere in that it is a cat and has two rudder T-foils. More similar to Hydroptere.ch minus the retractable steps/planing hulls.
From Doug Schickler on SA:
I would be remiss not to mention other supporters: cut-paste:
www.ribacomposites.it
www.modelleriabrussolo.com
www.styacht.com
www.YCI.it
www.angeloglisoni.com
Cantieri Punta Manara
Rostan
North Sails Carasco
---foils are supported partially and retracted by a carbon tube that is pivotably attached to the foil and pivotably attached to a sliding car on the underside of the forward cross beam-no "shocks".
Whites Dragons-mini hydroptere-esq-white-dragon.jpg  Whites Dragons-mini hydroptere-esq-mini-hydroptere.jpg  Whites Dragons-mini hydroptere-esq-mini-hydroptere-2.jpg
yes, it is a revolution
Old 10-21-2010, 08:52 PM
Doug Lord's Avatar
Flight Ready
Whites Dragons
From the front page of SA:
Concept:
The main goal was to create an easy boat, simple to transport, which can be sailed on foils instinctively, hardly different than a regular cat. Further, it had to be tremendously fast.
Design and Construction:
The two students designed and ultimately self-built this 2 person hydrofoil cat, almost exclusively of carbon fibre. Working with carbon A class hulls as a starting point, and borrowing the sail plan and mast directly from the Tornado class, they were well on their way. Simulation based design, tutored by Davide Tagliapietra, focused on flight dynamics, VPP, foil hydrodynamics (CFD) and accurate dimensioning of newly built components using Finite Element (FEA).
The choice of V (surface piercing-dl)foils, devoid of the need to actively alter the lift surface, fit the simplicity and transportability concept well. The hydrodynamics of the foil at the free surface, the limits on stability, and the impact on platform beam are the compromise.
Then they went and learned how to build a boat as well. Starting with pointers and tips from a small composite boatyard Punta Manara, they climbed the learning curve. At the end, vacuum bagging substantial components came easy. For the foils and main beam, they turned to the pros at Riba composites.
Here you see just how wide the platform is, with a trampoline 2x wider than long!
Principal Data
LOA 7m
LWL 5.5m
Beam 4m (!)
All up weight 125kg
Mainsail area 16.35 m2
Genneker ca. 17-20 m2
Testing and Refinement:
The project was first tested in tow in late September. Huge efforts were necessary to handle the concentrated loads on the platform induced by carrying the weight and developing the righting moment on such small areas. The tensile structure originally made of synthetic cables has been completely replaced first with steel rod and then remade with carbon straps to give rigidity.
By October the boat was sailing regularly and the results were convincing. The cat was flying high and stable on its hydrofoils, easily carrying one 75 kg person and even foiling with 160 kg of crew in 12 knots of wind. Handling was easy, just as predicted. The most recent session on Wednesday of this week saw the boat flying very smoothly and easily.
Speeds over 20 knots with only the main were achieved.
Tests were carried out with two crew and the genneker, pushing the boat ever harder. With the genneker, the boat was able to fly in about 6 knots of wind. Due to a lack of instruments, the best indication so far of sailing angles is that the apparent is well forward when the boat is up. Video.
Next steps for refinement will be concentrating on proper sizing and positioning of V foil fences in order of increasing high speed performance. One of the next steps will be further sail development, a new main, and a flatter genneker is also under development.
Further the team will address the righting moment limitations of the design. In addition to double trapezing, which has not been utilized to date, the mast will be significantly canted, providing a portion of the lift, allowing for a wider stance of the foils.
Plans:
Regattas such as Round Texel, Bol d’Or, Multi cento and perhaps some record runs. The boat will be at the Dusseldorf Boat Show in the new year, on display at the request of the Tornado World Champion Roland Gaebler.
Old 12-13-2010, 04:29 PM
Doug Lord's Avatar
Flight Ready
Whites Dragons
More on this cool boat: http://www.youtube.com/watch?v=7WqCL...layer_embedded
Old 06-25-2011, 03:08 PM
Doug Lord's Avatar
Flight Ready
Whites Dragons-surface piercing cat
More here: http://www.facebook.com/pages/Whites...45919742107493
click on image for superb detail:
Whites Dragons-mini hydroptere-esq-whitedragons-6-25-11.jpg  Whites Dragons-mini hydroptere-esq-whites-dragon-2-6-25-11.jpg  Whites Dragons-mini hydroptere-esq-whites-dragons-3-6-25-11.jpg
Old 06-30-2011, 10:27 PM
SouthernComfort's Avatar
SouthernComfort SouthernComfort is offline
Hillbilly Engineer
Rep: 46 Posts: 15
Whats the probability of one of these taking a sudden nosedive due to debris or part failure?
Old 07-01-2011, 11:12 AM
rapscallion rapscallion is offline
Rep: 129 Posts: 412
That looks like a fun ride!
http://janetcg32.blogspot.com
Old 07-01-2011, 11:25 AM
Doug Lord's Avatar
Flight Ready
From what I gather it is very well engineered so part failure is fairly unlikely. Hitting debris depends on the conditions where it is sailed. Probably unlikely.
Team Hydroptere has worked on a system to avoid partially submerged objects or objects just under the surface which is definitely important for a big foiler in the ocean.
Old 07-01-2011, 04:12 PM
Hillbilly Engineer
Rep: 46 Posts: 15
Thanks for the response. Sorry if it was a dumb question, i'm new to the true multi hull design world. My only multihull experience has come from 5 years building boat docks by way of a 30 foot pontoon, and my 24' pontoon. I didnt take into consideration the geography of where these would likely be sailed. I'm thinkin of my debris infested Cumberland river. Thanks again.
Design for Speed and Efficiency-Lessons from Hydroptere Doug Lord Multihulls 10 04-05-2010 04:16 PM
Hydroptere new record bistros Multihulls 5 11-12-2009 04:07 PM
Hydroptere Maxi Doug Lord Multihulls 2 04-17-2009 01:04 AM
hydroptere 52.83 knt bertho Boat Design 2 10-08-2008 10:56 AM
Hydroptere takes new direction Chris Ostlind Sailboats 2 05-30-2006 03:27 PM
