#121
| Hi RWatson, I had it built in Thailand primarily because of Creed who built the first Tiki 38. I thought that following behind him I could learn from his mistakes...and besides my background is power catamarans not sail so I am a novice in that department whereas Creed is a highly experienced sailor. Anyway, I did learn from Creeds mistakes and I added to that by learning from some of my own...primarily due to misplaced trust. Interestingly as it turned out I could have contracted for the same deal in New Zealand for less money, but I didn't bother checking at the time as I thought it would be fun to build at the same time as Creed and we could do a bit of crusing around South East Asia together. It was quite convenient as I have a subsidiary in Thailand so I commute back and forth quite reguarly. The 300% premium came about as follows: I was told by the builder that a progress payment was due when I was in NZ and beleiving that to be true I wired him the money. When I arrived to check out the boat it was miles away from being at the point where the progress payment was due. I had at that time sent him US$75,000 but there was less than US$25,000 worth of work completed...thus the 300% calculation. On hind sight I would have been best to have removed it from the yard and put it up for auction as is and started again in NZ or with Gunther Nutt in Phuket and not incurred the expense of shipping the hulls back to NZ and the additional expense of fixing the structural deficiencies. But...I didn't, so I only have myself to blame. I don't hold any illwill to ***** as it was my own fault for not being diligent enough at the time... But...he is beginning to annoy me with his childish name calling... We will see what evolves from this point on. Maybe quite interesting. Cheers, Warren |
#122
| RB changed info Quote:
"At the beginning, he and I worked to redraw the hull lines to better suit strip-planking." Well that's clear, no involvement of any naval architect mentioned anymore @ Alik, I apologize for the "one of you is ......" statement I made about this. That was also harmful to the one who was telling the truth, so I should not have said that. @ Jeff, thanks for the deleting of that inappropriate post. Regards, Angélique ![]() |
#123
| same thing happened to me Quote:
On the bright side, I probably would have paid for, and sailed off in, a death trap if I had not been diligent about progress pics. Trusting RB went out the window when Chris' replacement, one Allan Ganz, did not reply to my emails for 3 months prior to RB's progress payment invoice. cheers robert self |
#124
"Trusting RB went out the window when Chris' replacement, one Allan Ganz, did not reply to my emails for 3 months prior to RB's progress payment invoice." Sounds like he is still in Management Systems 101 after all the hard work training staff, and has yet to enroll in ethical business conduct course. "Its the age of Enron, baby" |
#125
| No properly built RB boat till to date? Quote:
Hi *****, 11½ years to teach your crew how to build a proper boat is from the start off your company until now. Does that mean that your yard has not delivered a proper boat till to date? Just curious Regards, Angélique ![]() |
#126
| Wharram lashings Quote:
#127
#128
| Wharram classic design hull beam connections Quote: Wharram classic design hull beam connection from below to above: - The connection bolts fixed through strengthened gunwhales. - Steel brackets fixed to the beams. - The connection bolts through the beam brackets. - The connection bolts through high compression rubbers. - Nuts on the connection bolts to press down the high compression rubbers to the brackets with's press down the beams to the hulls. - Flexibility is adjustable by the nuts on top of the connection bolts. See also: "Modifications to the standard plans can be dangerous." Regards, Angélique |
#129
| This is an interesting read: http://www.wallerdesign.com.au/Docs/...e%20Change.pdf |
#130
#131
| Rope beam lashings and 'felxibel fixed fastenings' on Wharram's Quote:
The 'felxibel fixed fastenings' I described is the old fastening system for Wharram Classic Designs and it was developed before modern high-tech synthetic ropes became available. Plan Sheet O7, 'Beamlashings for Classic Designs', is ment to use rope beam lashings on Wharram Classic Designs instead of the old attachment method that is standard on the Classic Designs. Regards, Angélique |
#132
| "But it's only a little change" Quote:
Regards, |
#133
| Quote: ![]() |
#134
| Court |
#135
| Designer redrew hull shape Quote:
******, You sent me this e-mail telling me that you re-drew the hulls and changed the design of the hull shape. Dear Rod, Saturday, February 7, 2009, 12:08:16 AM, you wrote: Dear Mr. *******, I am interested in buying a New Tiki 38 in Thailand that I understand you made significant changes to Wharram's design. Can you tell me anymore about the changes you made to this design? I notice the deck shear line is different, no chines, and I heard that the boat's keels are now sacrificial. Did you change the freeboard, bow angle, and hull shape? How did these changes change the overall structure of the boat? Thank you very much. Rod Jones ******'s reply: We have done modifications of hull shape only, on customer's request. The hull is re-drawn for round bilge shape and slightly increased displacment, but profile (and also sheerline) is same with the original boat. We've got sections of orignal Tiki and just rounded them to get new shape. We did not involve in structural design of this boat, this was done by customer and builder. Best regards, ****** ******* |
| Wharram plans to trade | sngatlanta | Marketplace | 2 | 11-23-2009 10:35 AM |
| Looking for Unused Wharram Tiki 30 Plans | tatoski | Marketplace | 1 | 11-23-2009 09:33 AM |
| Wharram Tiki 26 vs Woods Strider Club | resynth | Multihulls | 8 | 05-03-2009 12:22 PM |
| build a wharram or a Prout 37? | jah | Boatbuilding | 34 | 02-03-2009 11:26 AM |
| Dropdown Longshaft for Wharram Catamaran | Chris Bretter | Diesel Engines | 47 | 12-22-2008 03:42 AM |
