| Waterworld Trimaran I am a new guy-been looking on for a week or so finally signed up. I want to build an ocean going trimaran like the one in waterworld. Is there any plans on something like that? Do I need to commision a designer? Be gentle on me please. I have built about everything but a boat. I have built a Kirkham Cobra (latest project) to bridges, tilt-up buildings,prisions, etc. I am a civil engineer, contractor and a craftsman. I want to do this. |
| Hi Big Boss, If I were you, I'd start with a rowboat for kids, maybe something made of underlayment plywood. Just kidding! A friend of mine told me that Waterworld tri was modified and filmed in Hawaii--- his daughter worked on the film. I know nothing more but wish you luck finding the designer. Alan |
You can probably buy stock plans for an older ORMA Tri or just buy one. There are chater opportunities also. No offense, but if you don't know what an ORMA Tri is, you probably don't want one. ![]()
__________________ Proud supporter of The Far Kurnell Cat Racing Team I have not failed. I've just found 10,000 ways that won't work. - Thomas A. Edison |
| I know what an ORMA 60 is- I have MAPQUEST just like you guys! I want to make one. I do not know what "stock plans" are, though. Where do you get them? Thanks again. |
It's an ORMA Tri ... there are several, if not many designers that have done them. Find a designer that you like and ask them for a set of plans. You aren't going to make one unless you have a boat shop and experience with composite construction. There are ORMA Tris for sale. As a boat building project it would be a hassle and turning it into a nifty whiz-bang neato Water World boat would ruin it. Have fun ... Google is your friend.
| If you're keen on the "slightly rough" look, google an aluminium tri named "Tin Can". I hear you might be able to get that boat pretty cheaply and its only a few hours north of you... Seriously - if you want a big tri like that you'd be far better off buying a second hand one. The construction is pretty complex and there are nicely depreciated ones that can be picked up for not too much money. Beware the operating costs and hassle factor of a boat that size though. skimping on maintenance could be expensive in the long run and dangerous. |
You could call Larry Ellison and ask.
| Thanks guys. I have been following the "tin can" When I first saw it I knew where it would fail- I was right. To me it is obvious-had the welding been better he would have simply been out farther before failure, IMO. I do understand the pint the guy is trying to make, I hope he does. |
| Yes, there were two Waterworld tris. One went to somewhere in Florida last I heard and the other was completely refitted and is living in San Diego, going by the name of LoeReal. I found this page that looks at the boats in question, though the material is not up to date with photos. http://www.geocities.com/mariner767/index.html Attached below is shot of the way she looks in current racing trim Chris |
| After a little studing after your ideas- Damn that ORMA 60 is a big boat. I knew what it was before but after you comments I now understand waht I was seeing. I will be down south next month I will have to poke around and see if I can at least see one. Is there a boat that looks like that in a 40ft? What is the 39ft Ferrier (spelling?) like. Seems easy enough to build. Is it fast? THanks again. "Why start small? - When you can start big!" |
| If you are really serious about a 40' trimaran and have the desire to learn how to build, then you should talk with naval architect, Jim Antrim in the SF Bay area. He's a world class designer of incredibly fast multihulls with several offerings in the size range you mention. Here's his website showing the trimarans: http://www.antrimdesign.com/trimarans/ The 40' Zephyr, shown below, will absolutely give you the thrill you seek Chris |
If it were me and I didn't care much about cruising ... I'd see if a F40 Tri could be had for cheap. That would be a lot of bang for your buck. The F-39 is on my medium list, I like Farrier's stuff to a point and it is the biggest folder around. I think 45-50 is a better bet for a dual purpose racer/cruiser but that is a odd size, everything is either too full race for and old man to take his wife cruising on or too full cruise to make the thought of sailing fun for me. For a WaterWorld type boat Antrim would be hard to go wrong with.
| Kurt Hughes has a bunch of Tri designs in the c. 40' range. They range from a formula 40 to cruising tris with various levels of accomodation. http://www.multihulldesigns.com/stock/f40tri.html http://www.multihulldesigns.com/stock/40tri_rapid.html |
| Dick Newick's Ocean Surfer is nice too. Bit more solid than a F40. http://www.wingo.com/newick/oceansurfer.html |
| CATS of Waterworld...... The Movie | Wellydeckhand | Open Discussion: All Things Boats & Boating | 25 | 11-18-2011 05:13 PM |
| 6.5m Trimaran | VanIsleSailor | Boat Design | 3 | 07-05-2006 06:05 AM |
| Need help ,trimaran | petee | Boat Design | 3 | 08-19-2005 11:11 AM |
| Trimaran | Adz | Boat Design | 5 | 08-10-2005 12:13 PM |
| trimaran | Lem | Multihulls | 5 | 04-08-2005 04:48 PM |
