Old 01-07-2010, 11:42 AM
Pat Ross Pat Ross is offline
Corinthian 41 Tri #12
Rep: 11 Posts: 48
Ultimate Multihull - a Trimaran
If you have not seen this boat I think you will be pleased to take a moment and appreciate where multihulls are favored
http://www.multihulldynamics.com/new...?articleID=200
Pat Ross
Old 01-07-2010, 04:45 PM
david@boatsmith david@boatsmith is offline
Rep: 50 Posts: 85
That'sway cool. David
Old 01-07-2010, 07:48 PM
DaveJ DaveJ is offline
Rep: 66 Posts: 131
Hmmmmm manufactured by Austal, makes me proud to be an Aussie.
Looks to be a stealthy ship aswell (so those pesky priates can see it on their radar) by the slanted hulls.
Old 01-07-2010, 09:57 PM
troy2000's Avatar
troy2000 troy2000 is offline
Rep: 1686 Posts: 1,240
I think it's interesting that we're finally getting around to ships purpose-built for coastal waters again, to go along with our blue-water Navy. About damn time, I'd say. I gives us a lot more flexibility.
"All one has to do is follow the plans and build in no permanent leaks."
-Charles Minor Blackford, on the simplicity of building flat bottomed boats
Old 01-14-2010, 04:44 PM
joefaber joefaber is offline
Rep: 10 Posts: 17
Sweet!
It looks like some of the Navy's rigid sidewall research from the sixties and seventies is finally being put to use.
And she looks like she'd handle blue water pretty well.
Old 01-14-2010, 06:10 PM
Previous Member
Rep: 0 Posts: 0
I totally agree with you, Troy... and I wasn't even a Navy guy in the military. Boats like this one are the answer to the monster fleet thing from our Cold War days of solving the world's issues with a huge fist.
With the future looking like it'll be more and more small theater conflicts, the need to have vessels that can deal with those conditions and proximity are important. A smaller, faster fist that can do its job and not require a major mobilization to get it done.
Old 01-15-2010, 12:30 AM
sailsocal sailsocal is offline
Rep: 13 Posts: 50
Lcs 2
"She's aerodynamically designed"
That's an absurd statement, the upper deck structure is about as aerodynamic as a brick wall. Like most new military ships, everything above the water line is designed first and foremost to minimize radar reflections (i.e., no curved surfaces).
Old 01-15-2010, 06:34 PM
kach22i's Avatar
kach22i kach22i is offline
Architect
Rep: 1067 Posts: 2,299
It looks cool, no wonder the Navy could not say NO to her.
George: Architect (land lover type)
Hovercraft & Vintage Porsche Owner
http://www.boatdesign.net/forums/boa...ect-11973.html
Old 01-21-2010, 06:12 PM
Rep: 10 Posts: 17
sails,
aerodynamic isn't always curves.
and curved surfaces can minimize radar reflection.
Old 01-22-2010, 01:41 AM
Rep: 13 Posts: 50
Originally Posted by joefaber View Post
sails,
Yes, it is. You can't get laminar flow around planar surfaces joined by sharp edges.
Old 01-22-2010, 05:07 AM
Boston's Avatar
Boston Boston is offline
Rep: 1457 Posts: 3,355
If I remember this rightly the limiting factor of this type of hull is the wave height
once the waves basically start beating the daylights out of the connecting structures then its time to slow down
although Ive often wondered if some relief holes might not help that some
that and some creative forms to direct the wave pressure to release through the holes
this thing is probably fast enough to avoid the ugly stuff but still if I remember wave height is a key element
I am skeptical of the deniers diatribe
Old 01-22-2010, 07:26 PM
Rep: 10 Posts: 17
Boston,
The limiting factor you speak of may be true for boats.
the USS Independence, however, is a ship.
the following gives you a better idea.
General characteristics
Class and type: Independence-class littoral combat ship
Displacement: 2,176 tons light, 2,784 tons full, 608 tons deadweight
Length: 127.4 m (418 ft)
Beam: 31.6 m (104 ft)
Draft: 13 ft (3.96 m)[
Propulsion: 2× gas turbines, 2× MTU Friedrichshafen GmbH 8000 Series diesel engines, 4× waterjets, retractable Azimuth thruster, 4× diesel generators
Speed: 44 knots (51 mph; 81 km/h)
Range: 4,300 nm at 20+ knots
Capacity: 210 metric tons (206 long tons, 231 short tons)
and this video shows her at sea.
http://www.navy.mil/navydata/featurePlay.asp?id=62
Old 01-23-2010, 01:07 AM
Boston's Avatar
ya I'd still love to see it hit in a 10 meter wave
what they show of her is in a glass sea state and Im betting once the wave peaks make contact with the underside of her connecting tissues its time to slow that thing down to a crawl.
time will tell and eventually there will be shots of her in heavy weather
cheers and thanks for the flicker
that boat is really pretty slick
B
Old 01-23-2010, 01:12 AM
Asleep Helmsman Asleep Helmsman is offline
Rep: 62 Posts: 165
At forty or sixty knots, wind resistance is not going to be that critical. Remember air is one thousandth of the density of water.
The small amount of turbulence generated by the angles on that ship will be negligible. Even with its highly angular shape the F117 Stealth Fighter can approach the sound barrier. Its stealthy shape (F117) makes it harder to control, but a ship gets its control from the sea, not by redirecting airflow.
Wake me up if we hit something.
And you guys can Call me Joe
Old 01-23-2010, 01:18 AM
Boston's Avatar
there are several threads in here concerning this very issue and its been pretty clearly shown that wind resistance is an important factor in determining the resistance and energy required to propel a vessel.
they dont call it the wobblin goblin for nothing
all those shifting vorticies make it dam near impossible for even a computer to control
ultimate RC yacht supertrooper Boat Design 19 03-29-2009 08:49 AM
Arabian 100' Trimaran, Oman Sail's new flagship multihull brian eiland Multihulls 1 12-23-2008 09:32 PM
Arabian 100' Trimaran, Oman Sail's new flagship multihull brian eiland Multihulls 1 12-17-2008 05:53 PM
ultimate 3.5 M tri rapscallion Multihulls 6 09-24-2007 07:26 PM
The Ultimate Sailboat Brasstom Boat Design 17 08-07-2005 07:50 AM
